Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 12-25-2002, 01:49 AM   #1
wrexsta
Member#: 27521
2003 WRX sedan
Default Noobie Question. Need Help Fast!
My driveway is on a 40 degree uphill. When I push in the clutch to start the engine, the car starts to roll backwards. Keep in mind that the parking brake is still on and the car is still in 1st gear(I park the car in 1st gear). Is this normal? Is the car supposed to roll back even with the e-brake and 1st gear engaged?
P.S This is my first manual tranny car. I had never driven stick previously. I had to learn how to drive stick on this car. Could I have somehow messed something up? There was this one time when I drove about a block with the e-brake on(accidentally).. could this have worn out my e-brake or something?
wrexsta is offline   Reply With Quote
Old 12-25-2002, 02:20 AM   #2
esteve
Member#: 28716
2006 STI
Don't worry, everything you describe is normal. A 40 degree incline is a lot, so when you push in the clutch to start the car, it disengages 1st gear and unless you really crank up on the e-brake, the car might roll back. And driving for a block or so won't hurt the e-brake.
Because of your steep incline, you'll probably have to step on the brake every time you start your car to keep it from moving.
esteve is offline   Reply With Quote
Old 12-25-2002, 02:34 AM   #3
willow
Member#: 29515
2002 wrx
That is normal. Just remember whenever you step on the clutch all the way, the gear is practically in neutral.
It's good idea to step on both pedals (brake and clutch) whenever you start the engine. That way you will not roll back or foward. Be safe.
willow is offline   Reply With Quote
Old 12-25-2002, 02:47 AM   #4
BlueX003
Member#: 30483
2003 WRX
BLUE
yea, do what willo saids.... it's a very GOOD IDEA to start the car with your feet on the clutch and the brake!!!
BlueX003 is offline   Reply With Quote
Old 12-25-2002, 02:50 AM   #5
wrexsta
Member#: 27521
2003 WRX sedan
wooohhh... thanks guys.. i got a little worried there for a second. Me = noob
Old 12-25-2002, 04:15 PM   #6
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
I disagree that it does not hurt to drive for a block with the e-brake on.
I do agree to use the e-brake, but only long enough to get you moving. Hold the e-brake up with the button depressed. Then as you feel the clutch grab, ease the e-brake down.
Another way is to use heel-toe. You need a little more skill to do that properly, but practice makes perfect.
Is it really a 40 incline, or is that exaggeration? That would be steeper than ANY driveway I have ever seen.
Better get used to a burned clutch smell.
T-WRX is offline   Reply With Quote
nooby question need answer about brand and downpipe roccrew585 Newbies & FAQs 9 09-30-2007 10:20 PM
Noobie Question... need some suggestion !! THX lcw North West Impreza Club Forum -- NWIC 14 12-03-2006 07:22 PM
Coil pak question need help fast! JDM Importers Subaru Conversions 5 01-18-2006 07:59 PM
need help fast! help me get out of work snyper784 Off-Topic 10 10-17-2003 03:45 PM
