Notices
Old 12-25-2002, 03:39 PM   #1
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Default School me on RS cat pipes
Are all RS factory cat pipes interchangable.
I've got a '98.. can a '99 or 00-03 pipe swap in directly.
** I realize there are difference in the O2 sensors per MY but that not a concern.
Thanks.
Albert is offline   Reply With Quote
Old 12-25-2002, 04:24 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
you can swap directly with a '99-01... there won't be any difference in performance. I have'nt heard of the o2 sensors being any different...
~Brian
rhdude is offline   Reply With Quote
Old 12-25-2002, 04:41 PM   #3
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Thanks Brian.
Re the O2 sensors... I recall when the O2 recall on specific MAP cars was in full swing the part number someone posted was different from mine, that why I threw that in.
Old 12-26-2002, 01:22 PM   #4
cvalle-sd
Member#: 420
2001 Cr-V
The basic plumbing is the same, anyway. It'll bolt right up.
cvalle-sd is offline   Reply With Quote
Old 12-26-2002, 02:42 PM   #5
rhdude
Member#: 6637
I suppose you could always find a willing local member who has a 99-01' and try swapping o2 sensors to see if they fit. if they fit, and the clips are the same you won't have any problems, they are both 1V sensors But then again, My Minnam Downpipe's o2 sensor bung fit a 99 sensor, and it fits my car just fine... The only thing I would think would be different are the clips, but then again I would assume they are the same.
~Brian
Old 12-30-2002, 02:46 AM   #6
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
I thought the 99's used two of the same O2 sensors in the exhaust path and the 2000+'s used one of the same from the 99's and a new one maybe a wide band or something. But I'm pretty sure the 2000+'s use two different O2 sensors.
EDIT: Ah hell, I guess I should read a bit more thoroughly next time.
spshultz is offline   Reply With Quote
Old 12-30-2002, 04:14 AM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Unless that post that I referred to was the wrong P/N there is some sort of difference with the MAP ('02+) cars.
But since the bungs are all the same the rest is just for education purposes.
School me on PlayOn, Netflix, Hulu, etc. on PS3 -=C=- Off-Topic 14 03-02-2010 05:38 PM
OT...School me on Cats! wrx1986 Off-Topic 157 02-22-2008 09:22 PM
school me on taxes on money made from real estate.. lotusdrift Off-Topic 32 04-20-2007 04:59 PM
OT... school me on "Dog/Cat Poop Cleaning" Business INFIDEL Off-Topic 13 01-29-2007 10:17 PM
I need a spare RS cat-pipe? Centeral Florida Bobalouy South East Region Forum 12 07-29-2003 09:10 AM
