Old 12-25-2002, 04:29 PM   #1
imprezwrx
Member#: 23536
2000 impreza rs
blue ridge pearl
Talking I bought a pulley set
Like the title of the topic says, I bought a set of aluminum pulleys,
and the crank pulley is underdrive. The UD crank pulley weighs
1.2lbs, and both the power-steering and alternator pulleys are said to be .8lbs lighter. How much hp should I expect to gain from this? And wich CAI should I buy? The PRM(cobb) or the Injen?
imprezwrx is offline   Reply With Quote
Old 12-25-2002, 07:39 PM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
HP gains? ~4hp...
Are the UD pulleys the same diameter as the stock?
Have fun with the install
rhdude is offline   Reply With Quote
Old 12-25-2002, 09:22 PM   #3
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Man, that alternator pulley was a doozie. After damaging the alternator housing with "the screwdriver trick," I gave up and took it to the dealer to finish job.
Be sure to reset the ECU, that helps.
- Ken
Dr Ken is offline   Reply With Quote
Old 12-26-2002, 02:08 AM   #4
imprezwrx
Member#: 23536
2000 impreza rs
blue ridge pearl
RHdude, an Under-drive pulley is smaller in diameter than an OEM or stock pulley. And I think you're a bit shy as far power improvements go, you say ~4hp, I'm thinkin' more like 10-12, but we'll see.
And to Dr.Ken, thanks for the tip
Old 12-26-2002, 08:35 AM   #5
RaceCarRiot
Member#: 6542
1997 Ver IV
[gives imprezwrx a belated xmas flame suit.]
RaceCarRiot is offline   Reply With Quote
Old 12-26-2002, 11:01 AM   #6
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
You don’t actually gain any horsepower but rather you’re freeing up the energy that was used to move the additional mass of the pulley in a lightened pulley. 10-12 HP seems a little excessive doesn’t it? I would go for the Cobb intake but I may take a while to get it.
Poppa smurf is offline   Reply With Quote
Old 12-26-2002, 02:46 PM   #7
rhdude
Member#: 6637
no way in hell you'd gain 10-12hp... UD claims 4hp.
I have heard you don't want a smaller pulley, but rather a stock size, but lighter. I believe the GFB's are like that..
As for intake, Cobb makes a very very good intake, but they are expensive and hard to get your hands on one. Ganzflow's style is very similar, cheaper, and usually easier to get. It's all up to you
Old 12-26-2002, 02:53 PM   #8
imprezwrx
Member#: 23536
2000 impreza rs
blue ridge pearl
Ok, thanks you guys for lighting my candle
And I'm a positive guy, so let's deduct your 4hp from my 12, and we end up with ~8hp I'm the kind of guy who sees an ˝full glass, not an ˝empty one, happy new year to all of ya
Old 12-26-2002, 03:09 PM   #9
rhdude
Member#: 6637
Get a FAT or SPO/AVO intake, they add like 80-100hp
Old 12-26-2002, 03:20 PM   #10
sideways slut
Member#: 21085
2.5 rs-t
80-100hp, i hope that you are just bein sarcastic. as far as the pully goes, i went with the unorthodox racing pully and it is smaller and i hate it. first of all i noticed nothin as for as hp goes, second, it takes power from the accessories to give you more power, so all i notice is everytime im at a light, all my lights dim until i give it gas. not good if your also into a big sterio
sideways slut is offline   Reply With Quote
Old 12-26-2002, 03:37 PM   #11
rhdude
Member#: 6637
FAT and SPO/AVO are turbo kits
Old 12-26-2002, 03:39 PM   #12
sideways slut
Member#: 21085
2.5 rs-t
ohhhh
Old 12-26-2002, 05:35 PM   #13
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I always see the glass as too big.... so let say it adds zero HP, but make it easier for the engine to do its job.
moogoob is offline   Reply With Quote
Old 12-26-2002, 07:59 PM   #14
imprezwrx
Member#: 23536
2000 impreza rs
blue ridge pearl
Ok ok, so instead of writing that it "ads" hp to the engine, I should've said that it "frees" hp from the engine, since your 165 little ponies have to work less hard to do the same job, is that ok now? Can I go home now?
Old 12-27-2002, 02:51 PM   #15
DJ 9iron
Member#: 11349
2016 Mustang GT
the GFB pulleys are all smaller. Alt, pwr steering, and crank. It says it's so it doesn't underdrive, but i experiance light dimming below 1k rpm. I don't mind at all though. I love them.
DJ 9iron is offline   Reply With Quote
Old 12-27-2002, 05:19 PM   #16
imprezwrx
Member#: 23536
2000 impreza rs
blue ridge pearl
DJ, have you witnessed any change regarding re-acceleration???
I mean, if you lift up the the throttle and then pin it back, is there a slight improvement?
Old 12-27-2002, 09:08 PM   #17
DJ 9iron
Member#: 11349
2016 Mustang GT
yes, i really like it when i'm in 3rd rolling @ 3500rpm or more then nail it. It's alot better than stock.
Old 12-28-2002, 07:02 PM   #18
obyone
Member#: 16523
Actually, the Crank and Alt pullies are smaller sized but matched to keep the alt from underdriving. The Power Steering is stock sized so it is the only thing that is underdriven. They are also cheaper than the N1 pullies or the UD ones.
obyone is offline   Reply With Quote
Old 12-28-2002, 09:38 PM   #19
DJ 9iron
Member#: 11349
2016 Mustang GT
how do you explain my headlights dimming at idle? also, the power steering pulley is in fact smaller!
Old 12-28-2002, 10:15 PM   #20
obyone
Member#: 16523
Are you sure? J/k
You must have a set I haven't seen before. The GFB's I've seen had the crank smaller with the Alt to match, but the PS was stock size so that was the only thing being underdriven.
I just bought a new set of inline skates TimStevens Off-Topic 83 05-21-2009 12:36 PM
how many MAICers bought themselves a set of re01rs? nhat Mid Atlantic Impreza Club -- MAIC 266 03-18-2009 09:06 AM
Yay!!!!!111! I just bought a new set of tires Jard Mid Atlantic Impreza Club -- MAIC 8 04-27-2005 04:15 PM
Just bought an xtra set of 05 BBSs on eBay STiMUL8 Tire & Wheel 4 04-02-2005 03:29 PM
N1 Lightened Pulley set of UR Underdrive crank pulley CRAZY KEN Normally Aspirated Powertrain 12 10-05-2001 03:51 PM
