Old 12-26-2002, 07:35 PM   #1
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
Default help overheat
my car overheated last night in the snow. i did a search and came up empty handed. this is what happened: i hit a small snow man and was having fun in the snow doin donuts and driftsand what not, then my tirbo is glowin red hot and my car is steamin. what the heck happened? i took the car to the dealership to get it checked out. anyone know what happened?
i know i cant type
so what jus help me plase
thanks
jaime
red of the sun is offline   Reply With Quote
Old 12-26-2002, 07:43 PM   #2
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
kiss that turbo good bye and maybe your engine also. had that happen to me in my old conquest tsi
tekfoc is offline   Reply With Quote
Old 12-26-2002, 07:44 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Maybe all the snow blocked the air from getting through your radiator, so no cooling, so overheating. You should also check to make sure your fans are working.
Old 12-26-2002, 07:51 PM   #4
Gil
Member#: 20872
t3h rubber-neckers
must die!
in addition to having snow packed in your radiator, also take a look at your intercooler.
Did you notice your engine temp??
Gil is offline   Reply With Quote
Old 12-26-2002, 07:53 PM   #5
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
i let the car cool down for about an hour afterwards.
i started the car back up and no problems what so ever.
weird. but this morning it the gauge went to hot but it did not overheat. it was low on antifreeze so i filled it back up. the gauge went down and again it was fine. i dunno, its actin funny.
i hope nothing is wrong. i will find out from the dealer soon.
Jaime
Old 12-26-2002, 07:55 PM   #6
Gil
Member#: 20872
t3h rubber-neckers
must die!
hmmm. sounds like it COULD get complicated.
Old 12-26-2002, 07:58 PM   #7
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
the fan was actin funny and no ...in all the fun i did not notice my engine temp.
Old 12-26-2002, 08:00 PM   #8
Gil
Member#: 20872
t3h rubber-neckers
must die!
I think the first question you need to ask is what happened to the coolant. If it got into your engine for whatever reason, then it's gonna be pricey.
good luck with the dealer.
Old 12-27-2002, 09:26 AM   #9
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
When you hit the snowman, you may have damaged the radiator, or dislodged a hose. Hopefully the coolant was just spilled due to a loose hose. If the turbo ate it, you are in big trouble.
T-WRX is offline   Reply With Quote
Old 12-27-2002, 12:58 PM   #10
SilverBullet'02
Member#: 15835
You may want to check the bottom hose and clamp on the radiator. Mine was loose and caused my car to lose coolant and overheat. Luckily, it was discovered before any real problems occured.
SilverBullet'02 is offline   Reply With Quote
Old 12-27-2002, 07:39 PM   #11
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
Smile
got my car back from the dealer.
no leaks, no radiator problems.
turns out the snowman bent my ac condensor back a bit and my cooling fans were out of allignment.
got it fixed and my problem went away.i wowuld like to thnk u guys for all your help
i really appreiciate it
Jaime
Old 12-27-2002, 10:07 PM   #12
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
How much did it cost to repair?
Sounds like you lucked out.
Skyline is offline   Reply With Quote
Old 12-27-2002, 10:50 PM   #13
nqwan
Member#: 2916
02 duburu arr exu
happened to makinen in the subaru iirc, heh.
nqwan is offline   Reply With Quote
Old 12-27-2002, 10:56 PM   #14
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Yup, Rally of Sweden. Richard Burns hit a snowbank too, but he stopped to clear the radiator. Tommi didn't and DNF'd.
Old 12-27-2002, 11:17 PM   #15
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I guess now you know not to run over snowmen.
Mike Wevrick is offline   Reply With Quote
Old 12-28-2002, 11:24 AM   #16
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
it was fun but your right, i don`t plan on doin that again
It cost me 200 bucks. They did a complete check on my cooling system and flushed my radiator too. They also replaced the fans ...i could tell that they are new.
Old 12-28-2002, 11:25 AM   #17
red of the sun
Member#: 17565
2002 wrx sportwagon
red sedona pearl
Thumbs up
i would like to thank you guys again for all your help and concern.
i posted on the other site too and no one replied to me to help me out. guess i know where to go now for advice.
thanks again everyone
Help!! Overheat after tranny work ?? frederik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-28-2009 12:23 PM
Overheat?? pls help rip_sti_ra Service & Maintenance 4 08-12-2007 09:49 PM
Car overheats at idle when AC is on--HELP! wjc04wrx Service & Maintenance 5 05-06-2007 08:48 PM
Overheat Help sigma69pi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-30-2006 08:21 PM
Help car wants to overheat at idle seven881 Normally Aspirated Powertrain 5 03-16-2003 09:58 PM
