Old 12-26-2002, 10:09 PM   #1
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
Default replaced motor(2.2 to 2.5) and now clutch pedal is on floor!
i was jsut about to start my car for the first time with the 2.5 motor installed, but when i went to push the clutch pedal, i noticed it was about 1 inch from the floor..when you push it, it does move the fork a tiny bit..no where near enough.
the clutch is a cable-operated type(MY97 AWD Impreza L)
anyone have any ideas on what went wrong?
Murray (also posted in Trans. forum)
Murray is offline   Reply With Quote
Old 12-27-2002, 02:03 AM   #2
Slack
Member#: 17548
Did you make sure to reinstall the clutch spring? I just did a clutch job on my 2.2 and I saw a spring, so I looked it up in the service manual and found out that it was the ?clutch release spring? or something to that effect. I'm guessing when you release the clutch it pulls it back. Also, I'm not sure if this has anything to do with it but the RS clutch pedal sits much lower to the floor than the L.
Mick
Slack is offline   Reply With Quote
Old 12-27-2002, 04:21 AM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The RS is hydrolic and moves far less of a distance for operation.
Im wondering if there is a compatibility issue between the RS flywheel and the older clutch...
Old 12-27-2002, 05:21 AM   #4
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Just adjust the cable. If the flywheel is placed slightly futher forward than on the 2.2 then a little adjustment should fix it up.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 12-27-2002, 10:15 AM   #5
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
i had forgotten about the cable-type clutches needing adjustments after installation..last few clutches i did were cable type, but i dropped the trans, which meant the cable had to come off anyway..and those people actually replacedth e cables as well..in mine the trans stayed, but hte motor, flywheel, clutch and presure plate are "new".
i will go out and adjust the cable shortly..still have to get an O-Ring for #3 injector...
clutch pedal stays on floor when under load? ta ace Transmission (AT/MT) & Driveline 11 12-28-2009 12:04 AM
Help! Rebuilt my motor and now clutch pedal not coming up? mokujin22 Transmission (AT/MT) & Driveline 4 07-24-2007 08:44 AM
Rinsed engine and now oil light is on... ? gopsu Electrical & Lighting 6 04-19-2006 09:18 AM
WRX down for 3 months now and the clutch pedal is dead? Si2WRX Transmission (AT/MT) & Driveline 4 07-12-2004 12:11 AM
replaced motor (2.2 to 2.5) and now clutch pedal is on floor! Murray Transmission (AT/MT) & Driveline 6 12-28-2002 03:45 AM
