Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 12-26-2002, 11:29 PM   #1
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
Default clutch pedal vibration
Recently had an exedy organic racing clutch installed. Afterwards I started to experience some vibration in the clutch pedal, especially noticeable if I depress the pedal about an inch and hold it there. This is odd considering hydraulic pull-type clutches do not pick up engine vibrations. I also have had a clutch pedal squeek dating back before the new clutch also. Anyone else have this problem?
HS WRB-rex is offline   Reply With Quote
Old 12-27-2002, 02:02 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
sounds like one of the pressure plate forks is out of alignment.
jeremy
Old 12-27-2002, 11:13 AM   #3
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
That might also explain a faint rattle I hear under light throttle and a peculiar sound every so often when I disengage the clutch from 1st gear. However, I dont see how a hydraulic line can pick up vibrations from the pressure plate
So I'm guessing the car could be running fine short term? What are the long term consequences of this?
Old 12-27-2002, 01:48 PM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
well it could go away because it could be as simple as the disk hasa slight high spot that needs to burn off, it could also get worse which would be what happens when a pressure plate spring collapses. That's about all the information i can offer. It's definitely okay short term.
jeremy
Old 12-27-2002, 08:15 PM   #5
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
thanks for your input, anyone else familiar with vibrations in pedals with hydraulic lines?
Old 12-28-2002, 04:49 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yeah it's normal, just cause it's fluid doesn't mean you aren't going to feel it
jeremy
2009 WRX Clutch Pedal Vibration and Rotational Squeaking Sound Subirex09 Transmission (AT/MT) & Driveline 125 12-13-2013 12:27 PM
Clutch pedal vibration Dave99 Transmission (AT/MT) & Driveline 18 12-10-2010 12:07 PM
Clutch pedal vibration Cinna696 Transmission (AT/MT) & Driveline 0 10-27-2008 11:54 PM
new oem clutch -> gas pedal vibrates, any ideas? alexey_s Transmission (AT/MT) & Driveline 2 07-26-2002 08:08 PM
clutch pedal vibration OMAHA2.5RS Transmission (AT/MT) & Driveline 0 03-08-2002 03:52 AM
