Old 02-08-2001, 03:44 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Angry Impreza - problems with ignition coils?
I posted this earlier but couldn't find this on the forum when i went to check for responses so i am reposting it. My apologies to those who responded.
About 2 months ago i started to have a shuddering of my car as it was driving, at first i wasn't sure if it was a transmission/engine/fuel injection problem. Then i finally heard a sparking sound under my hood and found a current jumping from one of my iginition wires to a bolt on the engine block. I eventually got my car in the shop and they found out i had a burnt out ignition coil pack which was replaced and my car is fine. The strange thing is that within 3 weeks of me having this problem diagnosed, my friends MY2000 RS had exactly the same problem and not only had to take his car to the shop once, but twice to get the same ignition coil replaced. Also to top it off, both WRC Imprezas suffered the same problem which led to Burns pulling himself out of the Rally de Monte Carlo. Whats going on here? Does anyone else have a similar problem with his or her RS? I'm curious to know.
edkwon is offline   Reply With Quote
Old 02-08-2001, 05:43 PM   #2
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
The WRC Impreza I believe uses individual coil packs connected directly to the spark plugs, similar to the old Turbo Imprezas, SVX's and the new WRX. No plug wires( although the old "direct" coil packs were known to get a bit flakey as well). Just clarifying things a bit
FWIW, one of the Coil Pack's electrodes on my Mom's 98 GT LTD completely disintegrated with only a few thousand miles on it
Shik is offline   Reply With Quote
Old 02-08-2001, 07:11 PM   #3
dandbest
Member#: 1885
2015 Evo
Post
I have a 01RS, my father has a 99RS and we haven't had any problems yet....
Danny
dandbest is offline   Reply With Quote
Old 02-09-2001, 08:19 AM   #4
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Post
I had my car taken in for that also (spark jumping from #4 terminal on coil pack to bolt beside it and #4 terminal corroded with a small crack in the insulator for #4) and they replaced the coil pack and the spark plugs. A month or so later I noticed some chugging starting again...I check and the spark is jumping again from the same terminal!!! (Though the terminal isn't corroded as badly since I caught it earlier) so this time I cleaned off the terminal and replaced the plug wires and I swear the power shot up noticeably afterward (it felt like it had been lacking in power for a few months before the chugging started the first time). Hopefully it was just a problem the #4 wire and replacing the wires will fix it.
Warp3 is offline   Reply With Quote
Old 02-09-2001, 04:05 PM   #5
Dirt Man
Member#: 176
2011 Subaru Forester
Angry
Warp 3
Hello!
I've had this problem and it still feels like I'm bogging down. The dealer supposedly fixed this problem but I'm going to give your suggestion a shot. Thanks!!!!!
Dirt Man is offline   Reply With Quote
Old 03-07-2001, 06:23 PM   #6
Avenger
Member#: 1234
Post
Have you guys try to put some dielectric silicon (I think that is what is is called.) on the terminals of the coil pack? Maybe moisture is somehow getting in there and making the spark leak out, eventually causing a coil pack problem because it is jumping to ground with higher/lower (depending on the situation) resistance.
Avenger is offline   Reply With Quote
Old 03-07-2001, 06:33 PM   #7
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Yup. Same problem here. With pictures. And yes, I put dielectric grease afterwards on it. We'll see if it lasts.
Revision is offline   Reply With Quote
Old 03-07-2001, 08:54 PM   #8
Warp3
Member#: 161
06 WRX TR (SGM)
89 MR2 (Ice Blue)
Exclamation
Actually, even after the dealer replaced the coilpack and plugs, about a month later the chugging symptoms came back. I checked and the spark jump and corrosion had returned (except with less corrosion since I caught it sooner). I cleaned off the terminal and replaced the only related part left (the plug wires) and everything seems to be ok so far, plus I swear the horsepower went back up (I thought it had been lacking lately). Apparently, it was a faulty #4 wire after all.
Old 03-08-2001, 12:45 AM   #9
Molez93
Member#: 585
02 WRX
WR Blue
Exclamation
This post was a little old, but what the heck...
I too had a coil and coil ignitor issues. Both were replaced under warranty @ 35k on my 98 RS even with a Minnam Stage 2 installed.
I don't have many details, but would be happy to share via e-mail if necessary.
-Scott 98 Rally Blue RS
Molez93 is offline   Reply With Quote
Old 03-08-2001, 12:51 AM   #10
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
I too toasted an ignition coil on my 99 2.5RS.
DigDug is offline   Reply With Quote
Old 03-08-2001, 08:05 AM   #11
DigDug
Member#: 4077
1999 Impreza 2.5RS
Talking
Yes, using dielectric grease on the contacts of the coil pack.
And yes, I also had wire #4 sparking across. What a PITA...
[This message has been edited by DigDug (edited March 08, 2001).]
ignition coil problem... Juztjin Service & Maintenance 1 07-07-2006 08:13 AM
Question about impreza ignition coils jvgoff Normally Aspirated Powertrain 0 09-28-2005 02:15 PM
Ignition coil problems [email protected] Electrical & Lighting 4 05-14-2004 12:44 AM
High Milage/Ignition Coil Problems and Questions JJenkins Normally Aspirated Powertrain 5 07-18-2001 10:52 AM
('93-'01) Anyone have a problem with their ignition coil on MY99 IMPREZIV Impreza Forum 2 04-18-2001 01:37 PM
