Old 12-27-2002, 08:03 PM   #1
Rich10
Member#: 14934
Default Max boost with UTEC stage 1 and ABC fully closed
I put in my utec today and love the smooth acceleration. I was surprised that with the ABC fully closed, I was only getting approx 14.5 psi. The utec user manual says that at sea level (where I am), that I should get approx 15.5 psi at sea level. What are other people getting with their ABC fully closed?
Rich10 is offline   Reply With Quote
Old 12-27-2002, 11:29 PM   #2
peterex
Member#: 27021
2015 WRX
At a tad bit above sea level (Chicago), I am in the 15's running closed loop boost control without the ABC.
peterex is offline   Reply With Quote
Old 12-30-2002, 10:53 AM   #3
NeoGeo
Member#: 3776
Take a wild guess
Rich10, I'm getting exactly what you're getting with the ABC fully closed, on 4th gear WOT. I think that's pretty much what the factory setting is. When I open the ABC one turn, boost spikes appear, especially on 5th going partial to WOT, and boost can go up to about 17. That's where close loop can help you.
I'm near sea level, and winter air also helps to turn up the boost.
NeoGeo is offline   Reply With Quote
WRX 04-05 Turboxs UTEC with Remote Map selector and ABC VideoGameWrx Engine/Power/Exhaust 17 12-06-2006 05:25 PM
Power Loss on a 9-2x with UTEC Stage 1 Map, Logs, Dyno Plots, Graphs included. antrey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-16-2005 12:14 AM
UTEC Stage 1 and ABC? peterex Engine Management & Tuning 4 02-17-2003 01:01 PM
Max boost with TXS Stage 2, VF23 and stock injectors? muddywaters Engine Management & Tuning 7 01-22-2003 06:06 PM
TXS Stage 1 and ABC Combo Questions V8ETR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-04-2002 08:18 PM
