Old 12-28-2002, 02:58 AM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default 2nd oil change? and which oils to change ...
I changed my oil at 75 miles .... and now I believe I'm ready to switch to Mobil 1 .... having hit 3,000 miles.
Besides the engine ... which other oils should I change ... gear box, differential(s)?
Drive trains create so much power loss ... might as well put the slipperiest lube as possible in ... right?
makofoto is offline   Reply With Quote
Old 12-28-2002, 06:35 PM   #2
tdxflex
Member#: 13634
gear and diff oils don't get changed for a while. look in your manual or subaru.com for maintenance schedule.
tdxflex is offline   Reply With Quote
Old 12-28-2002, 07:22 PM   #3
makofoto
Member#: 25243
2006 Legacy Outback
I know I don't _have_ to change the gear box and differential oil for quite a while ... but others have suggested that it's a good thing to put Mobil 1 gear/differential oil in those units ... so why not from the "start?"
Old 12-28-2002, 07:55 PM   #4
Crashton
Member#: 3808
2005 Forester XT!!!
Crystal Gray Metallic
I know this subject has been beat to death, but since you asked here goes with my .02 worth. 3000 mi on your engine is probably enough break-in so go ahead & pour in the Mobile 1. If it was my car I'd wait till the next change though. As far as the gear box & diffs go I would definitely wait a while to pour in the Mobile 1. There is a fair amount of break-in that happens with the diff & tranny. Ever notice how much metal is stuck on the drain plug when you change gear oil? Those gears do a lot of seating into each other.
Crashton
Crashton is offline   Reply With Quote
Old 12-28-2002, 09:07 PM   #5
makofoto
Member#: 25243
2006 Legacy Outback
Chraston ... thanks ... makes sense ...
Changing AT oil/filter and differential oil juvenescence Service & Maintenance 6 06-17-2009 03:49 PM
Oil change and Transmission oil change help in Ann Arbor Scuter83 Mid West Subaru Owners Club Forum -- MWSOC 12 09-11-2006 11:53 PM
First oil change and first time to 6000rpm chirp the 1-2 Newbies & FAQs 22 06-12-2006 10:52 AM
('93-'01) Oil filters and other oil bits jeffg Impreza Forum 8 07-03-2001 05:16 PM
