Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 03-15-2001, 01:02 PM   #1
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Post
It is probibaly due to the fact that the Cobb shifter uses berrings instead of bushings. This would let more noise transfer through.
Josh
scoobiejosh is offline   Reply With Quote
Old 03-15-2001, 01:06 PM   #2
RallyGuy2k
Member#: 1146
Post
Did you modify the metal plate so that the linkage doesn't rub/rattle in 1st, 3rd, and sometimes 5th?
If not do a search for it and you'll find the mod...
If you look at that metal plate that holds down the rubber piece, you'll notice that the opening is a perfect rectangle except the top left (where 1st is)...
You need to cut that out to make room for where the bar now is...
Hope this helps...
Tre'
RallyGuy2k is offline   Reply With Quote
Old 03-15-2001, 01:11 PM   #3
RallyGuy2k
Member#: 1146
Post
Old 03-15-2001, 01:40 PM   #4
subenutt
Member#: 930
99 Impreza 2.5RS
Thumbs up
Congrats on the new shifter.
I have the same. The little noise I think your hearing, is the same as mine. Due to the berring. The bolt that goes through the bearing rattles with tranny vibration.
Nothing to be alarmed about.
I did notice it get louder when I installed another shift knob.
subenutt is offline   Reply With Quote
Old 03-15-2001, 01:42 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
Instead of cutting my plate, I bent it upwards to clear it. That way I can return it to stock and have no problems with the dealer if I ever have problems..
STiShawn is offline   Reply With Quote
Old 03-15-2001, 01:48 PM   #6
RallyGuy2k
Member#: 1146
Post
Sti...
Cool...probably a lot easier than cutting.
Tre'
Old 03-15-2001, 01:54 PM   #7
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
I have the same shifter, I also have some noise, but it sounds more like simple vibrating metal, only at higher revs...I think it is the little bearings shaking a bit. Doesn't really bother me, though.
jlyttle is offline   Reply With Quote
Old 03-15-2001, 02:34 PM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Wink
Rally Guy, tons easier, loosen screws, bend with pliers, re-tighten screws.
Old 03-15-2001, 07:09 PM   #9
Alex RS
Member#: 864
2000 Imrpeza2.5RS
BRP
Post
For those of you guys that say you have this shifter, how do you like it? I mean is it notchy like they say the Kartboy is or smooth? How does it compare to other short shift kits you've driven? I think that is one of the next things on my list, that's why I want to know.
Alex RS is offline   Reply With Quote
Old 03-15-2001, 10:19 PM   #10
subpreza
Member#: 2940
2002 AMG C32
Black Opal
Post
I sell and install the shifters. I had mine bent so it is lower and and closer to my leg. It also decreased the throw by a total of @ 75%. When installing the shifter you MUST regrease everything. Use a good moly grease and lather it on everything! The end ball, bearing, nylon washers, nut....grease it all very well and the noise will be gone! I also recommend a good weighted shift knob to get rid of the notchy feel.
subpreza is offline   Reply With Quote
Old 03-16-2001, 12:28 AM   #11
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Thumbs up COBB Shifter, Review and Questions...
Well, I got my Cobb Shifter yesterday morning ( thanks JJP), and installed it yesterday afternoon. Very nice piece, good finish,nice quality and very easy to install. It took me a whole 15 min to do it.It seems weird usung a chunk of wood and a hammer on my tranny. The throws are real short, solid and precise, made the stock shifter (which I liked) all that much better.
Now for my question: When I'm in gear and driving, the shifter/tranny/? makes a "shhhhhhhhhhh" noise. Only after I installed the shifter did it do this. Its real quiet, and sounds like static, no its not my stereo I turned it off. Anyone else have this, or know what it is? I greased the shifter, but it sounds like paper rubbing on something spinning, a dull, quiet "shhhhhhhhhhhhh". Did I do something wrong?
Old 03-16-2001, 06:36 AM   #12
chrisj
Member#: 582
1999 Impreza RS
Post
I sent a email to Trey asking if the shifter could be "cut down". I would like to have a shifter that not only has short throws, but also has a shorter physical height. Would this make the shifter REALLY tough to use?
chrisj is offline   Reply With Quote
Old 03-16-2001, 07:00 AM   #13
RallyGuy2k
Member#: 1146
Post
I love mine...I was thinking about cutting it shorter...as long as you know it'll increase the required pressure to get into gears your ok. I replaced my shifter knob with a lighter adjustable one and love it. (the shape is adjustable to fit your hand better)
Being lighter it didn't smooth out the notchy/mechanical feel but then again I really dig that feel.
Tre'
[This message has been edited by RallyGuy2k (edited March 16, 2001).]
Old 03-16-2001, 07:48 AM   #14
Matt
Guest
Member#:
Post
A little grease on the connection points took care of the bearings rattling for me.
I would also love to shorten the shifts even more, anyone know how withougt making the shifter even shorter ?
Old 03-16-2001, 07:56 AM   #15
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
I like the notchiness of the shifter, its very postive and precise, you know when its in gear. As for a heavier shift knob, I'd like a lighter, shorter OMP Suede knob I saw recently.....
Old 03-17-2001, 12:53 AM   #16
joostin420
Member#: 1046
2007 WRX Wagon
UGM
Thumbs up
this is what i did, check it out you will be very impressed. i Promise:
http://www.i-club.com/ubb-files/Foru...ML/001750.html
i absolutely love my design and cost me $100 dollars all together, and is WELL worth it.
pics installed further down in the post to show how much shorter it really is especially with my custom 2" tall shorty Aluminum knob.
justin
[This message has been edited by joostin420 (edited March 16, 2001).]
joostin420 is offline   Reply With Quote
02-07 WRX Cobb Shifter Bushings and KB XMember Bushing HokieRedRex Drivetrain 1 12-18-2008 11:33 AM
Cobb Shifter Bushing and KB Rear Diff Bushing HokieRedRex MAIC Private Classifieds 4 08-10-2008 03:50 AM
Cobb Catback Review and Sound clip KmanRuffian Car Part Reviews 3 10-06-2005 07:59 PM
Sbc Id Install And Uppipe Complete !! Review And Questions ! wrxhunter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-31-2005 02:21 PM
Perrin/Willwood 4pots--review and question rjrutzky Brakes, Steering & Suspension 3 09-30-2003 02:00 PM
