Old 12-29-2002, 04:55 AM   #1
legacyej22
Member#: 23385
Question I think I have dual port heads?
Ok I have been told that my car has single port heads, its a 95 2.2L legacy L. I was under there and took a look and it appears to have dual ports. Are there an engine gurus who can tell me for sure? Or anybody have picutres of their stock header? They look like dual ports but I'm sceptical because of what Ive been told. Have I been told wrong? Thanks
Josh
legacyej22 is offline   Reply With Quote
Old 12-29-2002, 05:50 AM   #2
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
It's pretty obvious which you have if you know what to look for.
The single port heads header is the same diameter basicly right till it hits the head. Like there is only one pipe comming off. No way it could be mistaken for dual port. The dual port heads are most simply described in a picture.
You can see the "y" shape of the dual port header on the bottom.
Hopefully this clears it up. I would like to start a registry for EJ22 owners that could help clear up some of the mystery of what years had single/dual port heads. I've had both personally.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 12-29-2002, 06:20 AM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
check this link, if you read thru the other head thread you would have seen all this info
http://forums.nasioc.com/forums/show...ght=EJ22+heads
More info then you'll ever need/want, also if you want to know more check out the other active Phase 1 head/Phase 2 block thread
Old 12-29-2002, 07:01 AM   #4
ChicksDigWagons
Member#: 20508
1998 Red Wagon
Not a bad thread, but still a bit inconclusive exactly what years came with what heads. SubyTechMaster came pretty close, but still didn't go into detail about years with the phase II heads, and the crossover. I suspect the 96 or 97MY has a mix of parts. The whole California spec deal throws a nasty wrench in the cog too.
And Jeremy, I swear wherever I go there you are!
I'll check out the other thread if I can find it.
-Brad
Old 12-31-2002, 04:44 AM   #5
legacyej22
Member#: 23385
Thanks a lot, well I thought right! Haha now one more question, will a 2.5L Header fit on my car? Thanks a lot
Josh
Old 12-31-2002, 04:56 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Josh
it should
EJ22 Singleport head to dual port heads Mechkiller31st Normally Aspirated Powertrain 7 11-14-2007 06:55 PM
2.2 single port -> dual port head swap beppomarx Built Motor Discussion 4 08-29-2006 09:01 AM
iON/Brullen equal-length header systems (For N/A guys with dual port heads only!) iON Performance Inc Engine/Power/Exhaust 0 10-21-2004 06:03 PM
Dual port head or Single port head ? G.Subramaniam Normally Aspirated Powertrain 5 06-25-2004 01:09 PM
How do I tell if i have dual port heads? RaceCarRiot Normally Aspirated Powertrain 24 11-19-2002 09:28 AM
