Old 12-29-2002, 11:48 AM   #1
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Default Jerky acceleration and sputter all of a sudden
hello, my car is a NA impreza 1995 L I am having problem with
sputter almost like backfire around 200 0 rpm it started 2 days ago it happens in any gear the the car is in @ first it just happened in 2nd now it does 1st -5th.
I baby the car and it has 115k on it. When I first got the car a year and a half ago I put new bosch platinum spark plugs in the car @ around 90,000 miles. Today it got worse happening @ around 2800 rpm and if I tap the gas sharply while it is parked with the parking brake up in neeutral (manual car) it can sputter for a second it feels like a backfire without the backfire sound could it be a sparkplug issue? MAF sensor? Could a PCV valve cause this @ just a certain rpm? please help this car is my daily driver.
thanks,
jay k
jkjersey is offline   Reply With Quote
Old 12-29-2002, 11:59 AM   #2
rhdude
Member#: 6637
2009 Acura MDX Sport
Subaru's hate bosch plugs.... Also, have you changed your spark plug wires?
fuel filter?
rhdude is offline   Reply With Quote
Old 12-29-2002, 01:47 PM   #3
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Default wires?
wires could cause this problem and plugs going foul could cause this problem and the problem would become worse all of a sudden not gradual? Yes I changed the fuel filter. About say 10,000 miles ago. What tools do I need do change the spark plugs? I may be able to ride up to autozone or pepboys and ride back to do it. I mean as far as hands on experience I can change my oil ... Are the spark plugs right behind the wire? I do not have a wrench here, the tools are @ my family's house which is a ways from here. What would be the size wrench I would need to change plugs?
Old 12-29-2002, 06:35 PM   #4
rayc
Member#: 21960
2012 Audi S4
09 WRX DGM
Hey, It should be the same as a 2.5. So you would need a 5/8 spark plug socket and at least a 5 to 6 inch extension. Pull the plug wires and plugs are under them.. Very easy job.
rayc is offline   Reply With Quote
Old 12-29-2002, 08:10 PM   #5
ej25power
Member#: 14771
02 RS
All Silver!
Did you push the plug wires onto the plugs HARD? It might seem like they're on, but they might not be. I made that mistake when I changed my plugs. Cost 100 bucks to figure out I didn't push hard enough. But the symptoms you describes are what I had
Geoff
ej25power is offline   Reply With Quote
Old 12-29-2002, 08:36 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
I would start with the plug wires, especially if they are OEM. Check the plug gap, I would change them with some NGK copper core plugs, you will have to change them every 30k, but they perform better than platinum plugs.
Jay McDade
Lincoln/Mercury/Jaguar Tech
Old 01-04-2003, 12:42 AM   #7
m750
Member#: 2278
8Sti | 07 allez
White | Comp
things to check:
plugs
wires
coil
02 sensor
I had similar symptoms when my o2 sensor was bad, and my plugs were loose.
AO
m750 is offline   Reply With Quote
Whine noise all of a sudden in WRX - all gears at certain times Civ2Sub311 General Community 38 06-14-2015 04:33 AM
No changes to car in 20k and now all of the sudden 18psi spike. MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-15-2005 04:44 PM
What's with all the dog killing all of a sudden? now with a sword mr_disco Off-Topic 10 09-02-2004 10:00 PM
24k miles on car and all of a sudden weird grinding noise when braking cold. Eric SS Brakes, Steering & Suspension 5 04-14-2003 07:00 PM
I'm a Subaru pimp and why is AlfaBill's wallet $185 lighter all of the sudden? Opie South East Region Forum 0 11-02-2001 11:19 AM
