Old 12-29-2002, 02:51 PM   #1
extraducksauce
Member#: 18555
SWRT BLUE (what else?)
Default Wheel WIDTH Play?
My new thing is watching Best Motoring and I noticed that with FR and 4WD layouts they play with the wheel sizes; e.g., narrower rear wheels. Doesn't this decrease the amount of understeer, and allow you to slide the rear with more ease? Have any of you tried this? I'm seriously considering using their technique.
extraducksauce is offline   Reply With Quote
Old 12-30-2002, 01:53 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Not recomended. Different weights/sizes on different wheels with FWD can cause damage to the differentials.
If you can afford differentials at will, then be my guest
Old 12-30-2002, 06:15 PM   #3
jmott
Member#: 6713
2007 Prius
brown
decreasing traction in the rear tires to get oversteer is a last ditch effort.
in theory the car shouldn't be any faster around a course. youve only got less traction.
jmott is offline   Reply With Quote
Old 12-30-2002, 06:42 PM   #4
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Running wider tires in the front seems to be common for FWD cars in auto-x, I know that ITRs in DS use this approach. For our cars, you would want to make sure that the diameters are very close, but I think that for example 245/40/17 in the front and 225/45/17 in the rear would probably be ok, and a potentially interesting setup.
TheWRX is offline   Reply With Quote
Old 12-31-2002, 04:32 AM   #5
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
You would likely have better luck running the same size tire on different width rims, i.e. 235x7.5R and 235x8F.
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 12-31-2002, 10:12 PM   #6
extraducksauce
Member#: 18555
i'm confused here. 235, isn't that tire width??? and what's 7.5 and 8, is that wheel width? if don't change tire width in accord to wheel specs your going to be in a world of hurt; furthermore, if the tire widths are equal (e.g., 235) you aren't changing the capacity of the car to oversteer . . . 235 in front and rear will create more understeer, which is inherent with 4wd and FWD cars.
my suggestion for wheel/tire size combo is this:
225 45 17 (front)
205 55 16 (rear)
using the same type of wheel and maintaining equal wheel/tire diameters will allow relatively even rotational forces, e.g., 45 17 vs/ 55 16; using narrower tires (205 vs. 225) in the rear will decrease the coefficient of friction aft of the car, and will thus create, in theory, more oversteer.
Old 12-31-2002, 11:56 PM   #7
Subdued
Member#: 15904
05 Impreza
09 Tribeca
Yes, actually you are changing the footprint of the same tire by wrapping it around a different width wheel and is a somewhat common yet subtle tuning trick. A 205 rear 225 front would be a bit extreme and if you are worried about tire to wheel specs you shouldn't even mess around with different size tires on an AWD vehicle.
My 2 cents.
Subdued is offline   Reply With Quote
Old 01-01-2003, 12:06 AM   #8
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
Let me make this a little clearer, I have a tendency too assume everyone is in my head...
Tires:
4X 235/45 17
( Same size tires all the way around )
Wheels:
front- 17x8 ET 48-53
rear- 17x7.5 ET 48-53
Here you are simply perturbing the protuberance ( sry bout' the alliteration ) of the tire patch a bit more on the rear to induce a slightly lower friction coefficient that graduates with speed.
The elegance of this set up, as apposed to different tire widths, is that it can be controlled much better with tire pressure and it is speed eccentric. At slower speeds, where the understeer is less apparent both front and rear rubber will remain close to traction balance, at higher speeds, as the tire wall flexes and the contact patch convexes the rear will loose more surface than the fronts due to its stretch over the wheel width, helping to offset the F/R dissidence. I do, however, feel there are better ways to balance your car than fussing over the tire/wheel size.
SLR-
Old 01-01-2003, 08:29 AM   #9
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Best Motoring is not always the best display of driver talent or car setup. Were they racing on a track or "drifting"? Most of that drifting stuff is just for show, and doesn't have much to do with traditional racing (trying to get around the track as fast as possible).
JGTC is a much better show for racing setup & technique.
-scott-
scotty305 is offline   Reply With Quote
08 Sti: Wheel width vs. Tire width VS. offset and more. HELP! Redneck Ricer Tire & Wheel 2 12-02-2008 09:20 AM
Tire width vs. Wheel width? yamahito Tire & Wheel 8 01-28-2007 05:21 PM
Upsizing: Matching wheel width to tire width and adjusting offset sonicblue Tire & Wheel 14 08-16-2004 02:28 PM
wheel width and tire width BlueScooby New England Impreza Club Forum -- NESIC 1 07-29-2002 05:03 PM
How will Kumho V700 section width change with wheel width? Patrick Olsen Brakes, Steering & Suspension 5 08-06-2001 11:19 AM
