Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 12-30-2002, 03:05 PM   #1
RaceCarRiot
Member#: 6542
1997 Ver IV
Question squeaking belt noise from rear of engine bay
my car is making this noise that sounds like a squeaking belt at idle...i replaced the alternator/ps belt thinking that was the problem since it was starting to fray around the edges anyways, but then i noticed it was coming from the REAR of the engine bay. it goes away as soon as i put light pressure on the clutch pedal, just pressing down far enough to take the couple cm of play out of it. so it's not even really pressing on it, just the pressure from resting my foot on the pedal is enough to silence it.
is the the throwout bearing nearing the end of it's life (or some other clutch related thing), or is it something in the engine? i'm also starting to feel this flat/boggy spot starting up off idle, which feels like the clutch slipping; you really can't get underway smoothly below 2000rpm, or the car feels like it's on the verge of a stall.
RaceCarRiot is offline   Reply With Quote
Old 12-31-2002, 09:27 AM   #2
akuhner
Member#: 462
2005 Saab 92x Aero
No more rally car...
I have the exact same symptoms on BOTH my cars, including the fact that the noise goes away when you put light pressure on the clutch. I'm replacing the throw out bearing and pilot bearing on Saturday because you might as well do both while you are in there. I just got a new clutch and pressure plate or I'd replace those too. From the sound of it, I'd have a new clutch on hand when you get this done.
Alex
akuhner is offline   Reply With Quote
Old 12-31-2002, 11:45 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
throw out bearing would be my best guess as well.
i have a slight squeak now... but i'm on like clutch #100... soon I'll have the replacement warranty clutch installed and hopefully all this garbage will be over with...
Jamie
www.subiegalracing.com
www.allsubaru.com
Old 12-31-2002, 11:48 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
subaru's throwout bearings are just straight up junk, i've never seen throwout bearings go after 30k miles but they seem to fail rather freqently on these cars.
jeremy
Old 12-31-2002, 12:32 PM   #5
RaceCarRiot
Member#: 6542
1997 Ver IV
yeah, i've had an entire new spare clutch assembly on hand for about 3 months now, since i thought i was going to be putting a lightened flywheel in the car, so no worries there if it suddenly decides to take a dive.
i just was curious if my diagnosis was correct, or if i'd still be suffering from this maddening squealing if i replaced the clutch.
odd noise from front of engine? TBone7281 Service & Maintenance 23 02-05-2010 12:23 PM
Burning rubber smell, plus smoke from back of engine bay? kirbykirb Legacy Forum 7 01-19-2009 06:17 PM
knocking noise from front of engine (drivers side) cm1wrx Factory 2.0L Turbo Powertrain 14 07-10-2004 01:38 PM
Squeaking/Creaking noise from rear suspension mesaro Brakes, Steering & Suspension 4 11-12-2003 11:41 AM
I have a rattling noise from rear of car. Help. Soon2Bgreat Brakes, Steering & Suspension 3 02-28-2001 05:42 PM
