Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 12-30-2002, 04:18 PM   #1
Teh Legacy
Member#: 9853
to keep your mouth
shut.
Default Cobb Stage 2 Motor
Anyone have the Cobb Stage 2 block and heads? what do you think of them? Gains? goods & bads? worth the $$$?
Teh Legacy is offline   Reply With Quote
Old 01-04-2003, 10:52 PM   #2
Teh Legacy
Member#: 9853
to keep your mouth
shut.
bump...anyone???
Old 01-05-2003, 04:19 PM   #3
watcher in the sky
Member#: 3513
1997 Legacy Outback
bump x 2 ... I am interested as well.
watcher in the sky is offline   Reply With Quote
Old 01-24-2003, 12:29 AM   #4
ForEveR2.5
Member#: 31736
2003 Impreza RS 2.5
BRP
bump x3
anyone?
ForEveR2.5 is offline   Reply With Quote
Old 01-24-2003, 09:48 AM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
did you check on wrxforums? I've not seen them in action, but I have seen the heads sitting on a counter and trey showed me what all he had done. They are very nice. Haven't seen the block tho...
mrbell is offline   Reply With Quote
Old 01-24-2003, 11:42 AM   #6
Section 8
Member#: 821
Skip the stage 2 heads, and just get the Clubracer cams if you want to go fast. You save 2000 dollars and your car will be faster, get stronger valve springs and a Haltec and you will be even faster for the same money. If you can't stand to have a CEL, then you may want to spend the the money for the stage 2 heads.
My car passed a tailpipe idle test with Clubracer cams, with the stock exhaust with no problems, it idled 10-15 minutes before the test.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 01-24-2003, 10:45 PM   #7
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Uh, are the Cobb street/sport cams the same as the ClubRacer cams?
DrBoy01 is offline   Reply With Quote
Old 01-25-2003, 12:54 AM   #8
joefocker20
Member#: 13745
2015 STI
Cams alone arent going to force air through restictive heads.. In order to make the most power, people will have to have a decent intake->TB or TBs->Manifold->Cams->Heads->Block capable of sustaining a higher redline->Bore the exhaust ports->Headers>High flow cat->midpipe->Muffler that dosent look like a folgers can so you dont get pulled over.
joefocker20 is offline   Reply With Quote
Old 01-25-2003, 03:53 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
except that your math is flawed since the EJ25 SOHC are not all the restrictive.
Old 01-25-2003, 10:20 AM   #10
Section 8
Member#: 821
Like above, the heads are not the biggest problem. The cams are the biggest limiting factor in the stock car, before the head, TB, intake manifold, everything aside from the exhaust and intake. Heads are not. Cobb themselves comment on the heads ability to flow on their website.
Yes, in order to get the MOST gains what you wrote is true, but that was not the question. The question was:
The answer is "no" unless you absolutly cannot have a CEL (then you might still get one anyway). By just going with the racier cam, you will be faster than the car with the larger stock profile cam, and worked heads, for significently less money.
By half a second.
cheeRS,
Greg
Old 01-25-2003, 10:33 AM   #11
Section 8
Member#: 821
No. Thre are Three Cams on their site, the Street Preformer, Club Racer and Race Profile. The Street Preformer is the mild cam that is suppose to not upset the stock ECU and throw a CEL. They usually doesn't but sometimes it does.
cheeRS,
Greg
cobb stage 2 vs. prodrive stage 2 oxtox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2005 08:59 AM
Cobb stage 2 (w mods) VS. Cobb stage 2 (w mods) Happy_Days Proven Power Bragging 7 11-28-2004 04:25 AM
Those who upgraded from Cobb stage 2 to stage 2.5 WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-29-2004 04:56 PM
Turbo XS Stage 2 or Cobb Stage 2???? NBWRX04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2004 07:32 PM
TXS stage 2 Unichip vs Cobb Stage 2 Access ECU ezatnova Engine Management & Tuning 8 02-09-2004 08:54 AM
