Old 12-30-2002, 07:14 PM   #1
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Default Injector noise
Ok so i have been hearing an odd noise coming from my engine bay. Tonight I did some poking around and it sounds like it is my #1 injector. The rest of them sound fine. It is a hissing noise coming from it upon letting off of the throttle. I expect a sound like this when hitting the throttle but not after it is released. Could it be stuck open?
I don't know much about injectors so I'm in the dark on this one. Any help would be appreciated.
Thanks,
Buster
www.awdsubaru.com
EvasionOfTruth is offline   Reply With Quote
Old 12-30-2002, 09:49 PM   #2
obyone
Member#: 16523
What do properly operating injectors sound like anyhow?
obyone is offline   Reply With Quote
Old 01-02-2003, 06:14 PM   #3
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Not sure of the answer to that one. The drivers side is nice and quiet.....I'm taking a guess it should be similar on the passenger side.
Buster
Old 01-04-2003, 09:16 PM   #4
obyone
Member#: 16523
Buster
Funny, my scoobs been acting up when it's cold. If I leave her outside overnight, when I start her up first thing in the morn, I hear a knocking sound comming from the driver side cylinder bank.
I don't know if it's just lifter noise, noisy injectors, piston slap, or real deal knocking. I just know that it's annoying ass hell because it's LOUD. Of corse, it goes away when the car warms up and never shows it's head when the temps do not drop below 30.
Oh well, Subaru it looking at it right now so I should have an answer in a few days.
Old 01-06-2003, 04:04 PM   #5
obyone
Member#: 16523
Just got a call from Subaru. I'm posting a new thread with the response.
Old 01-07-2003, 03:21 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the injectors should just make a ticking noise and that's it, a hissing injector would indicate an injector which is stuck open just allowing fuel by.
jeremy
Old 01-07-2003, 07:53 PM   #7
obyone
Member#: 16523
jeremy
Then wouldn't your mileage go down because the car runs stupid rich?
Old 01-07-2003, 08:11 PM   #8
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It would ruin your engine because the oil will be washed away from the cylinder wall. If you catch it fast the only issue will be excessive blow by in that cylinder and lower performance.
Old 01-07-2003, 11:47 PM   #9
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Is there any way to check the injector? Possibly pull it out and notice something visually? My gas mileage has been lower than normal but I associated that with the cel from the rear O2 sensor.
Buster
Old 01-08-2003, 04:35 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
not entirely true, it COULD hydrolock a cylinder(if mechanically stuck open), but if it's shorted to ground internally halfway thru the casing it could stay open half as much as a static injector would while maintaining enough of a stoich mixture to keep the car running. It's weird but i HAVE seen it. And a lil FYI, the Rear o2 has NOTHING to do with gas mileage
jeremy
injector noise normal? ezil71 Newbies & FAQs 5 06-23-2009 01:26 PM
fuel injector noise? 03bluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-01-2006 07:08 PM
2.2L engine injector noise Hum Bum Normally Aspirated Powertrain 4 08-15-2006 10:53 AM
Turbo bearing about to die? and injector noise Vince126 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-11-2006 09:57 PM
clicky noise? (is it just injectors?) chubb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-09-2003 08:14 PM
