Old 02-19-2001, 01:57 PM   #1
RallyCSX
Member#: 4281
2010 2.5i, 2000 STI,
Ae86, CSX Rally Car
Post fifth gear synchro
Has anyone replaced their fifth gear synchro? My car started grinding in fifth after a good dirt road beating . Unfortunately I do not have a warrantee ...
Is It a pain? Is there anything I should look out for? Any info would be great.
JAC
RallyCSX is offline   Reply With Quote
Old 02-19-2001, 02:04 PM   #2
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Post
Are you sure it just didnt catch rocks/dirt?
STi-Nismo Dood is offline   Reply With Quote
Old 02-19-2001, 02:09 PM   #3
RallyCSX
Member#: 4281
Ae86, CSX Rally Car
Post
I cant immagine how rocks and dirt can get inside the tranny...
Old 02-19-2001, 02:16 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
<FONT face="Comic Sans MS">Is it expensive for the parts? Not really. However, you have to drop the transmission (ie: remove it from the engine, pull the front 2 and the rear driveshafts, split the case, pull apart the main shaft, and there you go. I just had my 5th gear and 5th gear synchros replaced (under warranty thankfully).
Brian
AIM: NUrsalia ICQ: 84483950
http://members.nbci.com/_XMCM/northu...reza/index.htm
Is that a chicken up there? Nope, just the way he's holding the grapefruit!
</FONT f>
Old 02-19-2001, 02:29 PM   #5
RallyCSX
Member#: 4281
Ae86, CSX Rally Car
Post
So they commonly replace the gear along with the synchro? That sucks, I just bought the synchro for 14 bucks but I haven't bought the manual. I dont want to if I can get enough info and do the job without it. I have been inside the gearbox on my rally car so Im not new to cracking a case.
I just hate supprises....
JAC
Old 02-19-2001, 03:19 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Post
<FONT face="Comic Sans MS">No huge suprises I'm aware of, but you might need the main shaft nut and washer too, as they are stamped over the main shaft to keep it from backing off under use (that was actually what happened to my tranny... the nut loosened, backed off, and the movement/wear broke number 5).
Brian
</FONT f>
Old 02-19-2001, 05:03 PM   #7
Tensecgn
Member#: 2102
Post
You have to pull the trans and remove the rear extension housing.5th gear is on the outside of the rear part of the trans.No need to split the case.The nut has to be removed that is staked,a roll pin,and then you slide 5th gear off.Then you just reverse the order to install.
Tony
Tensecgn is offline   Reply With Quote
Is 1st gear Synchro linked to 4th synchro in anyway?? WRexxer Transmission (AT/MT) & Driveline 1 08-21-2005 09:23 AM
Top Gear vs. Fifth Gear dr_wheel Off-Topic 31 09-23-2004 06:31 PM
Top Gear (not Fifth Gear like I last posted) Vid of EVO 8 vs STi Impreza01 STi Forum Archive 37 06-22-2003 01:46 AM
('93-'01) fifth gear synchro...again watcher in the sky Impreza Forum 7 12-16-2001 06:16 PM
fifth gear synchro RallyCSX New England Impreza Club Forum -- NESIC 4 02-19-2001 09:39 PM
