Old 02-19-2001, 03:26 PM   #1
555wagon
Member#: 2809
'00 Moto Guzzi
'91 Talon Rally Car #373
Post Strange noise from clutch pedal
My car is a 2000 2.2L OBS w/ 5 speed. Above 3500 rpm there is a faint constant clicking noise that is coming from the clutch pedal. It goes away if I depress the clutch slightly (1/2" or so). It seems to do this in every gear. This clutch is cable operated so my guess is something is iffy in the trans and is using the cable as a microphone.
Any ideas on what is happening? Thanks
555wagon is offline   Reply With Quote
Old 02-19-2001, 08:23 PM   #2
555wagon
Member#: 2809
'00 Moto Guzzi
Post
Anybody? Does this sound major? The problem has been going on for a few weeks with no change in the noise.
There is a rally cross this Saturday and I don't want to be on a flatbed for the ride home. Thanks
Old 02-20-2001, 04:55 AM   #3
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
my clutch pedal sort of creaks at the end of its travel..... not sure if this really helps you... actually I'm positive it doesn't..... sorry.
LUME is offline   Reply With Quote
Old 02-20-2001, 09:44 AM   #4
Retsyn
Member#: 1910
2 Left Feet
Post
Could be worse. My wife's Forester's clutch makes a repetitive squeak unless you put a little pressure on the pedal. REALLY irritating... Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak Squeak ...
Retsyn is offline   Reply With Quote
Old 02-20-2001, 10:36 AM   #5
555wagon
Member#: 2809
'00 Moto Guzzi
Post
I don't have the pleasure of the repetitive squeak. Rather, it sounds like a freewheeling bicycle from a distance. I'm thinking throw out bearing. Any opinions?
Old 02-20-2001, 10:55 AM   #6
gnurider
Member#: 455
2000 Impreza 2.5rs
aspen white
Unhappy
i hear the same thing on my MY2000 RS, i step on the clucth and i hear a faint squeak, i've never owned a manual tran before, so i didn't know if it was normal or not, but its just a faint squeak, is it something to worry about
jt
gnurider is offline   Reply With Quote
Old 02-21-2001, 12:12 AM   #7
bluesubie
Member#: 767
04 FXT
Post
I had a squeak in my 97 OB similar to the way Retsyn described his wife's Forester. First diagnosed as clutch pedal squeak, then cable squeak, then bad throwout bearing. Clutch assembly replaced (by order of SoA) and it still squeaked. Tranny opened up again and clutch fork replaced.
If it's the TO bearing or clutch fork, you should be able to hear it from then engine bay and/or underneath the car.
Seems like yours is a click instead of a squeak.
Dennis
Old 02-21-2001, 12:45 AM   #8
555wagon
Member#: 2809
'00 Moto Guzzi
Post
It's definately a high speed faint click above 3500 rpm, not a squeak. It seems rpm dependant but is easily drowned out by engine noise. I'm going to try and get it over to the dealer and see if they have any ideas.
Thanks for the posts
Click noise from Clutch Pedal? krinksta Newbies & FAQs 34 11-22-2011 08:03 PM
squeaking noise from clutch pedal? sjw Newbies & FAQs 5 05-28-2004 09:10 AM
Strange BOV behaviors and strange noises from turbo tr3 Factory 2.0L Turbo Powertrain 2 01-09-2004 07:06 AM
Help: Squeaky/Creaky noise from clutch pedal... Robmat Transmission (AT/MT) & Driveline 3 10-15-2003 03:41 PM
"Spring" or "Rattle" noise from clutch pedal bjteel Warranty Issues & SOA Problems 7 05-30-2002 03:17 PM
Message Board Statistics All times are GMT -4. The time now is 01:28 AM.
