Old 12-31-2002, 01:36 AM   #1
SubaruEJ25
Member#: 9722
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default Problems with 5th gear HELP
When I'm in 5th cruising down the highway at 60 or 65 mph then floor it everything is fine until about 80/85 mph. At that point the rpm's jump and the drop a few times in a row the car stops accelerating. It then SLOWLY picks up speed from that point on. All of my other gears in the car are fine with no hesitations or slipping. When I race I hardly ever use 5th because the race is over by that point. And the car only does this about 80% of the time. I have 40k on the car with the original clutch but drive well and really don't burn it. I can't figure it out its been doing this for a few days now. I think it is weird because it only does it in 5th. Any suggestions are welcome.
SubaruEJ25 is offline   Reply With Quote
Old 12-31-2002, 02:43 AM   #2
imprezton
Member#: 22958
2011 Land Rover LR2
Gray
try resetting your ECU first. It sounds like it may be fuel-cutting too low.
imprezton is offline   Reply With Quote
Old 12-31-2002, 11:24 AM   #3
SubaruEJ25
Member#: 9722
2000 Impreza 2.5 RS
Blue Ridge Pearl
Never thought of that one I'll give it a try and let you know Thanks
Old 12-31-2002, 02:12 PM   #4
watcher in the sky
Member#: 3513
1997 Legacy Outback
clutch is beginning to slip. I will almost gaurantee that. It starts in the higher gears like that. Dont know the technical reason why, but that is what happened with mine.
watcher in the sky is offline   Reply With Quote
Old 12-31-2002, 02:14 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Your clutch is gone... Time to change it
The technical reason has to do with torque multiplication but whatever...
Eric
Eric SS is offline   Reply With Quote
Old 12-31-2002, 02:22 PM   #6
watcher in the sky
Member#: 3513
1997 Legacy Outback
ah, i thought it was fun and exciting to watch as it trickled down into 4th, 3rd and finally 2nd... Everyday i woke up, i ran to crank my car, wonder, oh, oh how i wonder how bad it will be today.. and when will i come up with the money to fix this sloppy clutch?
Anywho, fix it before you get stuck on a hill. Soon, it will seem as if you are driving around in neutral
Old 12-31-2002, 03:24 PM   #7
SubaruEJ25
Member#: 9722
2000 Impreza 2.5 RS
Blue Ridge Pearl
Thanks guys, I was afraid of that. It looks like I'll have to start saving up now But at least I can get a racing clutch and finally get rid oh Subaru's soft and squeaky clutch!!
Old 01-01-2003, 11:27 AM   #8
Slack
Member#: 17548
Just take it super easy on your clutch or you will risk causing cracks in your flywheel. The same thing happened to me and I just replaced it w/ an ACT clutch kit. When I examined the flywheel, it had started to crack in a few places from the heat. Also when you replace it, try scouring the flywheel with an emory pad.
Mick
Slack is offline   Reply With Quote
Old 01-01-2003, 03:25 PM   #9
outback2.5HO
Member#: 15135
95 GF WRX
Your clutch is toast...
Go for an ACT or RPS clutch and a lightened flwheel while you are in there.
Also, HAPPY NEW YEAR!!!
outback2.5HO is offline   Reply With Quote
Old 01-01-2003, 03:27 PM   #10
outback2.5HO
Member#: 15135
95 GF WRX
That's "lightened flYwheel"...
Still a little slow today...
Sti Trans problems with 5th gear!! zmaster Transmission (AT/MT) & Driveline 4 03-28-2007 01:29 AM
Problems with 5th gear HELP SubaruEJ25 Transmission (AT/MT) & Driveline 2 01-01-2003 08:35 PM
problems with car in 4th and 5th gear help!!! wrxracer Texas Impreza Club Forum -- TXIC 6 02-02-2002 04:21 PM
Attn: RS owner with 5th gear problems Patrick L General Forum Archive 4 01-17-2001 04:14 PM
Odd Problem in 5th Gear only CBLOCK Normally Aspirated Powertrain 4 12-19-2000 11:14 AM
