Old 12-31-2002, 06:26 AM   #1
Genner
Member#: 18372
Default 52mm guages in Din will it fit?
Hello everyone!
Will 52mm guages fit in a single din? Say if you replace the factory hu with an aftermarket hu. Will the 52mm guages fit even if they stick out a cm or so?
thanks,
genner
Genner is offline   Reply With Quote
FS in NEPA: MadDad V1 Blackout/Amber 52mm guage set (EGT, Oil PSI., Boost.) specialgoodness Interior/Dressup/Audio & Security 12 10-29-2008 03:44 PM
How to put a 52mm guage in the left vent of an 05 STi? sgtpeper Interior & Exterior Modification 25 12-06-2006 10:21 AM
Only two guages in Din slot? mike270 Interior & Exterior Modification 0 03-06-2002 09:11 PM
Question to those with Omori 52mm guages in center of dash. Corn-Picker Factory 2.0L Turbo Powertrain 5 02-13-2002 02:16 PM
Message Board Statistics All times are GMT -4. The time now is 10:34 PM.
