Old 02-19-2001, 10:38 PM   #1
Jessie James
Member#: 2072
Question Turbo: What are you using (and does it do you good?)
Hey, if you are running a turbo, would you mind posting what turbo you are running, what size block, and what fuel/ignition/etc computers you are using.
Like: Garrett T04, S-AFC, ITC, on a 2.0l block. Goes great in 1 and 2, 3 and 4 lags.
Or whatever.
Much appreciated...
Mac
Jessie James is offline   Reply With Quote
Old 02-20-2001, 05:05 AM   #2
Rich L
Member#: 961
1999 RS-Tw/ CobraMAF
Custom Rallispec kit/IC#1
Post
Well, Im probably using the smallest turbo in the club. Its a Mitzubishi TD05-12A-8CM2 on my 2.5L. Im set up for a mild 6psi so the only fuel mod needed was a new fuel pump and FPR (and an IC).
I am very happy with the results! Thanks to Rallispec's custom job, I have a very drivable/fun car with a strong mid-range. I will post times when Atco opens on 3/2/01.
Rich L is offline   Reply With Quote
Old 02-20-2001, 06:29 AM   #3
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Question
Rich, did your car get finished Dec 30th or so? If it did, I saw it waiting to have my turbo put in. Nice intercooler
T3/T4, EJ25, TEC-II, ~6psi, goes like stink but needs more top end
RyanC is offline   Reply With Quote
Old 02-20-2001, 06:59 AM   #4
Rich L
Member#: 961
Thumbs up
Yes its quite sexy isnt it?!
I wanted Andy to sign it because its production number 1. It should be worth millions on Ebay after Rallispec makes it big time.
I'll wait till I have the big bucks before I upgrade my daily driver into 12sec 1/4 mile monster. If not, Im going to need to drive a used Hyundai to get by... and that would suck big time!
Thanks for the compliment Ryan.
Old 02-20-2001, 08:54 AM   #5
Jessie James
Member#: 2072
Talking
Thanks guys - anyone else?
Mac
Old 02-20-2001, 09:08 AM   #6
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
I started out with a Minnam kit many moons ago. It has slowly evolved into a RalliSpec setup. Garret T03/T4, 2.5L, Bell RRFPR, S-AFC. The AFC isn't doing too much and is relegated to the glove box.
After the last "upgrade" from RalliSpec, which consists of a new upper IC pipe, 2.5" up-pipe, and 3" down-pipe and exhaust, the car is again transformed. Lag is definitely not an issue. My car pulls very hard and seems to continue to generate more torque and horsepower all the way up to redline.
After I get back from VIR in early April, I'll take my car to Atco to see how it has improved in the 1/4 mile.
Steve
http://www.lagging.com
SteveS is offline   Reply With Quote
Old 02-20-2001, 10:02 AM   #7
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
I've got a T4 Garrett on a 3.3 liter V6 (SVX-T) with a Vortech SFMU.
kastle
<A href="http://www.azscooby.com" target="new">azscooby.com</a>
kastle is offline   Reply With Quote
Old 02-25-2001, 08:56 PM   #8
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
IHI RHB5 Legacy Turbo, JCS TCII and RRFPR on a 2.5L - two 440cc injectors being added next weekend.
ImprezaRS dot com is offline   Reply With Quote
Old 02-25-2001, 09:07 PM   #9
Jessie James
Member#: 2072
Post
Two injectors? Do tell - mounting them in the intake manifold or something? I'm thinking about that, too. Are you using something pre-made to control them, or custom, or ... ???
Thanks!
Old 02-25-2001, 10:01 PM   #10
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Post
T3/T4, Spearco intercooler, Rallispec full 3" exhaust, Tech II. Boost, depends on the day. It will be permantely set at 10psi as soon as I relocate my tech boost controller. Right now its about 7psi.
+'s include no lag, goes like stink, looks really cool
-'s include constant exhaust leaks, and blown trannies
MattC is offline   Reply With Quote
Old 02-25-2001, 10:35 PM   #11
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Post
2.5 liter Phase II Block
T3 turbine with T4 compressor wheel
2" uppipe
2.5" downpipe
2.5" turbine back exhaust with 2 hi-flow cats and Flowmaster muffler
Vortech SFMU
Vishnu Fuel Pump
Runs very strong at 5psi. I get a few pings when it is warmer outside (> 75 degrees). My Rallispec intercooler should be here in the next week or so, then I will probably run 7psi until it gets hot then back down to 5psi. I am still on the stock clutch as well.
AaronB is offline   Reply With Quote
Old 02-25-2001, 11:31 PM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
Post
Old 02-26-2001, 01:46 AM   #13
ASR
Member#: 1945
Talking
We used to run a T04E/50 on our car on the street running 21psi. 12.5 in the 1/4 on pump gas with bad 60ft times.
bigger injectors, pump, management, etc
ASR is offline   Reply With Quote
Old 02-26-2001, 04:13 AM   #14
ralyrcr
Member#: 1769
2006 Pontiac GTO
2009 Forester
Post
I too started with a minnam kit and have slowly upgraded. i have a t3/t4 with a sparco top mount intercooler. i have an hks evc4 boost controler, hyper afc, overbored stock injectors, holly 255 l/hr pums, vortec fmu pres riser, and lots of other junk. ran a 12.998 on 9 psi, and have only gotten slower with changing things, i need, and recomend some serious computer controle.
jon
ralyrcr is offline   Reply With Quote
Old 02-26-2001, 11:15 AM   #15
tluzziracing
Guest
Member#:
Post
ihi rbh5 turbo,rrppr,fuel pump,JCStorque chip2,3" exghaust,big IC,6psi and runs great.
Old 02-26-2001, 02:23 PM   #16
nathan power
Member#: 2208
Talking
2.5 block
T-28 Garrett
JCS IC 6x18
Bell rrfpr
Fuel pump
Running 6psi
sunoco ultra 94
Rallispec 2.5 exhaust
Needs to be tuned right, but gose like hell.
nathan power is offline   Reply With Quote
iPhone users: what apps do you use and what do you recommend? trustWRX Off-Topic 23 10-09-2008 03:55 PM
Are you pessimistic and if so, do you think that's a bad thing? Hamsterstyle Off-Topic 19 02-02-2007 03:26 PM
('93-'01) gc owners: what lowering springs are you using and how low, and how much did you pay? legacy2003 Impreza Forum 37 11-06-2004 04:57 AM
How does a flywheel work and what does it do? Dirty B Transmission (AT/MT) & Driveline 8 01-31-2003 03:15 PM
Roll call: What header & highflow cat are you using, and do you have a CEL too? BongMan Normally Aspirated Powertrain 35 09-16-2002 07:31 PM
