Old 12-31-2002, 01:34 PM   #1
scottsubarus
Member#: 5336
1992 SVX
Default Oil pan gasket replacement on a 2.5 Legacy??
Have a 97 Legacy GT (auto) I had the rear main seal replaced 3 months ago where I work (tansmission shop) noticed a oil leak dripping from same location a month after rear main was done. I finally got it back to the shop to be re-checked and was told it's the back of the oil pan now. They really don't want to tackle that kind of job they said, and from what I have seen in instructions for tubo kits(to replace the pan) it doesn't -sound- all that hard. Has anybody tackled this kind of job before?? any helpful hints??
Scott
Omaha
scottsubarus is offline   Reply With Quote
Old 12-31-2002, 02:09 PM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
It's rather easy from what I've seen. We can do it in no time.. it's just messy and you want to be sure to take your time.
We can talk more about it tomorrow if you want.
omahasubaru is offline   Reply With Quote
Old 12-31-2002, 03:18 PM   #3
jdk
Member#: 26114
06 rs
Arrow
The gasket isn't paper one but a liquid gasket kind (if its the same as my car)--one trick I havn't seen on the forum yet ,once you have the engine jacked off the mounts a little and bolts out,
is too take a rigid spackle knife and hammer it between the pan and block (on the corners). Leaves no marks and pops off in less than a minute...w/ no deformation off oil pan
jdk is offline   Reply With Quote
Old 12-31-2002, 04:16 PM   #4
scottsubarus
Member#: 5336
1992 SVX
Thanks all! after posting this, I did a "search" (like I should have) and found some helpful hints that were discussed. Again thanks!
Scott
Old 01-01-2003, 03:43 PM   #5
outback2.5HO
Member#: 15135
95 GF WRX
Good luck with the fix...
and HAPPY NEW YEAR!!!
outback2.5HO is offline   Reply With Quote
Old 01-01-2003, 09:05 PM   #6
rhdude
Member#: 6637
2009 Acura MDX Sport
RED ATV gasket material, can be bought at any autoparts shop...
when you put the pan on, bolt it down lightly, let it set 10minutes, then torque it down... make sure you clean the oil pan surface off, and clean the oil pan out thoroughly.... the block is made of aluminum, its soft and easy to scratch, so be carfeful!
rhdude is offline   Reply With Quote
EJ20 Oil Pan gasket or liquid gasket maker? jayfressh Newbies & FAQs 8 05-07-2016 06:21 AM
STi Oil Pan on 99 2.5 Engine? Soulofdarkness Normally Aspirated Powertrain 3 05-31-2009 04:31 PM
99 Legacy Oil Pan Gasket? SubbyOBS Service & Maintenance 6 11-12-2008 10:09 PM
AVO on a 2.5 Legacy GT Inder Normally Aspirated Powertrain 3 03-07-2008 05:40 AM
2 or 4 tire replacement on 2000 2.5 RS zakats Tire & Wheel 10 07-17-2005 08:00 PM
