Old 12-31-2002, 09:58 PM   #1
nekard
Member#: 12927
2002 Impreza WRX
Default STi gauge cluster temperature sensor
I was wondering if anyone with the STi gauge cluster has attempted to find the outside temp sensor. If so how much was the sensor and was it easy to install?
nekard is offline   Reply With Quote
Old 12-31-2002, 10:43 PM   #2
Austin
Member#: 7089
2016 STi
It's the same outside temp sensor that comes on the Outback Sport. I have the part number around here somewhere... Maybe I'll find it later. You can go to the dealer and buy one. Not too expensive, but I can't remember exact $$.
Austin is offline   Reply With Quote
Old 12-31-2002, 10:52 PM   #3
nekard
Member#: 12927
2002 Impreza WRX
That would be awsome! Thanks a bunch. Do you know where they put the sensor on the outback?
Old 12-31-2002, 11:02 PM   #4
Austin
Member#: 7089
2016 STi
It mounts in front of the radiator, center of the car at the bottom. There's a black vertical support with a square hole in it - that's where it goes.
PM user "iv30" - I emailed him the part number, maybe he still has it handy. Be sure to post it back here... just in case I can't find it.
Old 01-01-2003, 01:17 AM   #5
Davenow
Member#: 23676
Where it mounts is not nearly as important as what it plugs in to.
Any Ideas???
Old 01-01-2003, 02:59 AM   #6
Austin
Member#: 7089
2016 STi
Any Ideas???
The sensor plugs into the JDM instrument cluster. AFAIK, all you'll need to fabricate is the wiring between the sensor and the instrument cluster. I can't say for sure yet - I should be recieving my JDM instrument cluster Thursday or Friday.
Old 01-01-2003, 03:01 AM   #7
nekard
Member#: 12927
2002 Impreza WRX
What are you going to do about the KM to miles conversion on the odometer?
Old 01-01-2003, 03:03 AM   #8
Austin
Member#: 7089
2016 STi
Not worry about it.
Old 01-01-2003, 05:44 AM   #9
JustDSM
Member#: 17502
Do any of you know the specs of the sensor? Instead of an "ouside air temp" sensor, wouldnt it be cool to have a IAT readout in your Dashboard?? Just an idea...
JustDSM is offline   Reply With Quote
Old 01-01-2003, 06:51 AM   #10
kawshon
Member#: 15092
Chapter/Region: HIIC
06 imp, 92 alltrac
Hurry up Austin, I just installed mine also
Oh and thanks for the oil pressure gauge info.
Teiva-boy
(I'm using a friends computer...)
kawshon is offline   Reply With Quote
Old 01-01-2003, 12:23 PM   #11
Davenow
Member#: 23676
Default UM
I have the JDM STI cluster in my car, and there are no extra plugs on it for this sensor that I can remember. The wires wouldnt run that far anyway, they would go into the harness and run to the pins of one of the plugs already in use.
Its more a matter of finding out which ones. Which no one has been able to do as of yet.
BUT PLEASE let us know if you figure it out. You will be a hero to many.
Old 01-02-2003, 03:06 PM   #12
AVT
Member#: 21203
Bump, many of us have been trying to get to the bottom of this.
There is a thread HERE, but we haven't solved it yet. There is no connection on the cluster itself. There must be a plug somewhere in the engine bay, but WHERE is the question.
Just scanned this:
AVT is offline   Reply With Quote
Old 01-02-2003, 06:38 PM   #13
Austin
Member#: 7089
2016 STi
I'll look at the wiring diagrams tonight (if I have time) and see where the connection ends. My guess is that the appropriate wire is already laid in the harness from the ecu to the engine wiring harness connector, and all we'll need to do is wire the sensor into the engine wiring harness connector.
Old 01-02-2003, 08:03 PM   #14
zacek
Member#: 19467
04 WRX STi
WR Blue - original owner
the connector F78 (2-pole black connector - with Black Pink and Black Blue wires) should be around on top of the left horn if looking at the car from the front, somewhere behind the subaru emblem. This assuming the connector is in the U.S. harness and just sitting there. However I have not seen this on the few times I have looked around the grill. This 2-pole connector terminates on the cluster connector B (the middle green one) on pins B11 (BP) and B8 (BL). I need to see if those wires are there or not.
zacek is offline   Reply With Quote
Old 01-06-2003, 12:33 PM   #15
AVT
Member#: 21203
You basically just sumarized the picture I posted above.
I have yet to see this connector If anyone finds the wire (even if there is no connector), please let us know.
Old 01-06-2003, 02:02 PM   #16
Tobey
Member#: 21400
2015 WRX Limited
ISM
on my car they weren't there. i did a quick look without pulling the bumper off. they may be burried underneath somewhere but i can't verify that.
i want to do this mod with an obs fuel/temp gauge damnit!!
Tobey is offline   Reply With Quote
Old 01-06-2003, 04:39 PM   #17
Austin
Member#: 7089
2016 STi
I found the part number for the sensor and ordered it from Subaruparts.com... I'll post it when I get home.
Old 01-06-2003, 04:43 PM   #18
teiva-boy
Member#: 22825
73730FE010
teiva-boy is offline   Reply With Quote
Old 06-08-2011, 02:43 AM   #19
Foxkevin89
Member#: 272844
How can I get the outside temp gauge on the 06 sti cluster to work in the 04 wrx wagon? The temp sensor is deff reading something I think cuz it says like 47 degrees when it's really like 70 outside. Anything I can do to fix this?
Foxkevin89 is offline   Reply With Quote
Old 06-08-2011, 02:50 AM   #20
cjsgarage
Member#: 281406
unless you are using the entire harness from the donor car, I would venture to say that the air temperature sensors are different between the 04 and 06
cjsgarage is offline   Reply With Quote
Where can I buy a WRX STi Rear Differential Temperature Sensor? sssupercar Private 'Wanted' Classifieds 5 02-20-2008 11:48 AM
Where can I buy a WRX STi Rear Differential Temperature Sensor? sssupercar Transmission (AT/MT) & Driveline 1 02-15-2008 08:56 PM
WTB: WRX STi Rear Differential Temperature Sensor! sssupercar Private 'Wanted' Classifieds 0 02-15-2008 08:02 PM
WTT '04 STI gauge cluster for '04 WRX gauge cluster + $$ Lexington MWSOC Private Classifieds 29 08-03-2006 12:27 PM
STi gauge cluster temp sensor nekard Interior & Exterior Modification 0 12-29-2002 03:17 AM
