Old 12-31-2002, 10:09 PM   #1
AKGC8
Member#: 1305
2000 Impreza
Default Wierd problem with WRX swap?
Hey I've just about got my WRX swap done, just trying to work out some bugs.
Was having an overheating problem, but I think I've got it fixed. Pretty sure it was due to air pockets still in the cooling system.
Having a problem though with starting the car when it's warmed up. It will turn over but won't start. After it cools down it will start up again.
This is an 02 WRX engine in a 94 1.8l Impreza L.
AKGC8 is offline   Reply With Quote
Old 12-31-2002, 11:54 PM   #2
scuzzy
Member#: 29214
05 WRX Wag (Work)
91 Legacy Wag (Play)
sounds like the ECM thinks the engine is
overheating. or it could be purely electrical.
I had a similar problem in a 91 camaro, come to
find out it was the anti-theft system going haywire.
Does it throw a CEL light? some don't even throw CEL
lights, your computer should know, so if you feel so
inclined and your local parts store has loaner OBD2 scantools,
borrow one.
scuzzy is offline   Reply With Quote
Old 01-01-2003, 12:40 AM   #3
spiralsmurf
Member#: 16085
2005 STi
did you perform this swap yourself?
spiralsmurf is offline   Reply With Quote
Old 01-01-2003, 01:14 AM   #4
scuzzy
Member#: 29214
05 WRX Wag (Work)
Gack! didn't see the "turn over" part
you've got something heating up and not firing, if you have an
anti-theft system, some are designed to disable the fuel
injectors to prevent any kind of start. it could be
everything from distribuitor getting too hot and grounding out,
to vapor lock.
Old 01-01-2003, 02:10 AM   #5
AKGC8
Member#: 1305
2000 Impreza
Yea, did the swap myself. May try to get ahold of a scanner. I didn't even bother hooking up the CEL light because I knew it would throw one since I haven't hooked up fuel evap stuff yet.
Old 01-01-2003, 02:13 AM   #6
AKGC8
Member#: 1305
2000 Impreza
If the engine does overheat will the ECU cut it off?
Old 01-01-2003, 04:53 AM   #7
spiralsmurf
Member#: 16085
2005 STi
if you dont mind me sort of sidetracking but i was wondering how you did all the wiring and what you resources did you need to do the wiring yourself?
Old 01-01-2003, 05:29 AM   #8
AKGC8
Member#: 1305
2000 Impreza
I did the wiring myself, I live in Alaska and nobody does the swap up here. I used the FSM's for both cars. I pretty much used all of the WRX's engine harness and wired it into the L's system. Basically all I spliced into from the L's system is power and instrumets.
Old 01-01-2003, 03:19 PM   #9
spiralsmurf
Member#: 16085
2005 STi
is it that simple? how long did it take? i was paying someone to do this swap for me and after 3 weeks of them not getting anything done because of "wiring complications" i ended the deal. and now i'm planning to do it myself.
Old 01-01-2003, 06:31 PM   #10
AKGC8
Member#: 1305
2000 Impreza
It was pretty complicated because I had to tear apart the WRX's wiring and rebuild what I needed. Once it was done though, all I had to splice into was the power, instruments, and the radiator fans. I didn't use A/C, but that would be another thing I would have had to splice into.
HELP. wierd problem with halo lights ryan900 Electrical & Lighting 4 03-21-2010 12:02 AM
Wierd problem with Battlefield 2... shemoves Off-Topic 7 06-29-2007 03:36 AM
Wierd Problem with blinkers/headlights MobbDeep222 Electrical & Lighting 5 10-26-2006 12:47 PM
Wierd problem with my Mac StuBeck Off-Topic 65 04-10-2006 09:50 PM
Wierd problem with the board... Digital_Boy General Forum Archive 3 07-14-2000 04:22 PM
