Old 02-20-2001, 12:09 AM   #1
brendon
Member#: 3618
Exclamation a\f gauge problems please help fast
just installed autometer a/f gauge and it has one yellow light on all the time and doesnt ever move while driving. the same light stays on with engine off but key on. is this normal? checked the wires like 5 times. how are these things supose to act?
brendon is offline   Reply With Quote
Old 02-20-2001, 07:04 AM   #2
inpreza kid
Member#: 3334
Post
which wire did you hook it up to? did you hook it up to the rear o2 sensor? it should jump a bit as you get on the throttle.
inpreza kid is offline   Reply With Quote
Old 02-20-2001, 07:21 AM   #3
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
I think you wired it wrong? Are you sure you connected to a white wire (B136 #18)? Mine jumps around. The only time the mid-yellow light stays on is when I'm going at a steady speed.
tmat3 is offline   Reply With Quote
Old 02-20-2001, 09:04 AM   #4
brendon
Member#: 3618
Angry
no. i wired it to the white wire #18 on 136 and it doesnt move a bit
Boost gauge stuck at zero, compressor surge, big problems, PLEASE HELP!! offset Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 10-09-2007 01:23 PM
Apexi EGT gauge problem please help STiEric Electrical & Lighting 0 06-07-2007 06:11 PM
boost gauge problem, please help. daybreak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-12-2003 01:36 AM
Boost gauge install problem please help dolinga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-28-2001 10:24 PM
('93-'01) Gauge light problems please help me Texas25RS Impreza Forum 1 04-25-2001 08:44 AM
