Old 02-20-2001, 01:24 AM   #1
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Question Unstable throttle % on S-AFC?
Finally get my S-AFC on my MY00 Legacy. Everything works good, except when the engine is on, the throttle % reading on S-AFC is unstable. I checked the sensor voltage reading. It looks like it's not getting stable power to get correct reading. The strange thing is, when the engine shuts off with ignition key on, the reading is 100% accurate.
I checked the ground wiring and rewired 2 ground wires and the wire for throttle %, but didn't change a thing.
I also checked the settings, In 5 out 5, cylinder 4, throttle arrow points northeast.
could it be a bad TPS sensor or just my bad wiring skill? I use walmart type splicers and swapped them when I rewired the 3 wires. Any input?
Jason is offline   Reply With Quote
Old 02-20-2001, 05:41 AM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
...when the engine shuts off with ignition key on, the reading is 100% accurate.
There's no such thing as 100% accurate. Repeatable maybe, but not accurate.
Back to the original question - it's normal to see noise on electrical lines. The noise is caused by spark plugs, distributors (both electronic and otherwise), electrical fans, pumps, radios, etc. Only worry if the TPS % readings drift by more than, say, 2% with the engine on. It's no wonder the TPS is stable with the engine off...
-WaC
Wayne
wac is offline   Reply With Quote
Old 02-20-2001, 10:19 AM   #3
Jason
Member#: 105
2000 Legacy GT Ltd
WHT
Post
It varies as much as 20%.
Old 02-20-2001, 03:16 PM   #4
XTREME 2.5
Member#: 3330
Post
I have the same problem with my AFC. It varies all the time.
XTREME 2.5 is offline   Reply With Quote
Old 02-20-2001, 04:25 PM   #5
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
Then it sounds like you have a questionable ground connection for the S-AFC. Did you follow the instructions and connected the ground wires in the proper order? Also make sure that it is firmly connected to a good ground wire at the ECU, and not wrapped around just any bolt stud.
My TPS varies by 0.2% max during cruise. Try a highway run with the cruise control on, and see how much it varies on level sections.
-WaC
Wayne
TPS % on a STI swap? 2000GTB Subaru Conversions 6 07-15-2007 04:56 AM
Tint % on a silver 03 2.5 milla Tri-State Area Forum 18 01-24-2003 11:27 PM
Air Flow reading 00.00% on S-AFC???? HpiRally Normally Aspirated Powertrain 9 03-13-2002 06:38 PM
'normal' Prs (manifold pressure) setting on S-afc IMPREZAmike Normally Aspirated Powertrain 1 07-24-2001 12:52 PM
99 RS air flow % on a SAFC does any one know Jimmy Normally Aspirated Powertrain 3 04-05-2001 09:34 AM
