Old 04-06-2001, 06:01 PM   #1
Void
Member#: 5540
Post "Clutch Fluid"
My car: 98 RS
My question: Are there any negatives to replacing the standard Subaru DOT 3 "clutch fluid" (brake fluid really) with DOT 4? My fluid seems to be overheating during drives of any length and the pedal looses all resistace. The guys at my service department said this was the only possible problem/fix, but they werent sure the stock clutch is able to "accept" anything besides the standard fluid. Maybe a dumb question, but I wanted to make sure. Thanks
Void is offline   Reply With Quote
Old 04-06-2001, 06:05 PM   #2
Member#: 67
1999 Outlasting
the competition.
Post
that was one of the first things i did to my car. i changed all the fluids to some good Motul dot 4 fluid
[email protected]
Old 04-06-2001, 06:06 PM   #3
Tobias_Ostapchuk
Member#: 554
2002 Subaru WRX S/W
Post
...My 1998 RS used to do the same thing on warm and humid days. I solved the problem very easily. I purchased a WRX.
(I had TOO MANY problems with the RS!)
Tobias_Ostapchuk is offline   Reply With Quote
Old 04-06-2001, 06:08 PM   #4
Bottom Feeder
Member#: 2808
Post
Where the heck did you go to get this diagnosis? I can't imagine what toture you would have to inflict onto your car in order to overheat the clutch fluid. I've heard of racebikes boiling brake fluid, but a car overheating clutch fluid... geezus.
Get a second opinion somewhere else.
Bottom Feeder is offline   Reply With Quote
Old 04-06-2001, 08:36 PM   #5
gaylemd
Member#: 2643
2001 2.5 RS
BRP
Post
Go ahead and change it to DOT 4. The manual says you can use either or.
Mike
gaylemd is offline   Reply With Quote
Old 04-06-2001, 11:13 PM   #6
cvalle-sd
Member#: 420
2001 Cr-V
Post
I did the same as Kartboy I noticed when my clutch pedal got all "funny" Disengaging only at the furthers travel of the pedal, low pedal position, sticking, etc. I put in the Motul and prob Solved.
cvalle-sd is offline   Reply With Quote
Old 04-07-2001, 04:53 AM   #7
EchoWrx
Member#: 4101
2000 Impreza
Lightbulb
Yes, Use DOT4 synth-brake fluid and read this...
http://www.i-club.com/ubb-files/Foru...ML/000238.html
Good Luck
Gill
EchoWrx is offline   Reply With Quote
Old 04-07-2001, 03:17 PM   #8
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Post
It is not a good idea to change to DOT 4 because the seals in the clutch resivior and in the slave cylinder are not compatiable with the DOT 4 fluid. The seals will swell over time and begin to leak.
I have never heard of clutch fluid getting hot enough to fail.
CUNNINGHAM is offline   Reply With Quote
Old 04-07-2001, 06:58 PM   #9
superstring
Member#: 4577
1998 2.5RS
Black Diamond Pearl
Talking
Hey Void!
I'm trying to sort the same problem with my car (98 RS). Funny thing is that I'm on my fifth clutch (warranty replacement to try and cure shudder) and the first three shuddered but didn't have the problem under discussion. #4 - no shudder but....
I'm tuned in with interest!!
superstring is offline   Reply With Quote
Old 04-08-2001, 04:04 AM   #10
EchoWrx
Member#: 4101
2000 Impreza
Angry
CUNNINGHAM IS WRONG!!!
In my 2000rs manual page 10-29 it says use dot 3 or DOT 4! The only time when you can't use dot 3 or 4 is when you use silicone DOT 5 brake fluid. Call a dealer or any dealership for any car and ask. Synthetic fluid DOT 4 will not boil as fast and will not cause harm to the seals.
Old 04-08-2001, 04:42 AM   #11
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
This dude is correct. You can use DOT3 or DOT4 fluid for brake or clutch. I have used Valvoline DOT4 synthetics many times in different vehicles.
You cannot use DOT5. That's only for Corvettes and other fast cars (I think).
tmat3 is offline   Reply With Quote
Old 04-09-2001, 12:51 AM   #12
Wheels
Member#: 5410
2008 BMW 335XI
Post
Replace the gearbox fluid and the rear diff fluid to synthetic. I`ve never had a problem with over heating but I have had a problem with hard gear changes in winter and really sloppy ones in summer.
Wheels is offline   Reply With Quote
Clutch fluid flush/replacement? GQ Transmission (AT/MT) & Driveline 0 03-31-2002 04:18 PM
Different Clutch fluids kaos200 Transmission (AT/MT) & Driveline 3 09-03-2001 03:26 PM
Bleeding/Replacing Clutch Fluid North Ursalia New England Impreza Club Forum -- NESIC 3 07-01-2001 08:11 PM
How to Check? - Clutch fluid T-REX Normally Aspirated Powertrain 3 06-27-2001 01:55 PM
Interested in changing your clutch fluid? P.K. Motorsports Normally Aspirated Powertrain 0 04-14-2001 10:36 PM
