Old 01-01-2003, 04:58 PM   #1
Matty
Member#: 13408
2008 LGT
black
Default Question about grounding Mod install...
I'm doing an install right now...I'm not the most mechanically inclined..but feel like I can do this...I did a search on installs and pics...and I'm seeing several different configurations...Some show several connections to the negative post..others show only one or two and doubling up on other ground points..Is there only ONE way to connect the grounding Mod or as long as I'm connected to 4 0r 5 different spots I'll be OK ??? help please pictures a plus...but wriiten advice would be great too
Matty is offline   Reply With Quote
Old 01-01-2003, 05:02 PM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
It's best to have one wire to each ground point you selected; all originating from the battery.
Albert is offline   Reply With Quote
Old 01-01-2003, 05:51 PM   #3
Matty
Member#: 13408
2008 LGT
black
Default Got it done...Thanks...went with three
from the negative terminal ...did double up on the manifold ground..over too the chassis ground ..seems to run alittle more smoothly...have to take it out for A little better run..
Question about Grounding mod.. abosworth Normally Aspirated Powertrain 3 09-10-2005 07:22 AM
Question about Ground Control Coil-Overs Spectre186 Brakes, Steering & Suspension 4 01-15-2005 02:06 AM
question about ground control scoobydorift Brakes, Steering & Suspension 13 03-19-2004 01:54 AM
Question about Ground Control Coilover Sleeves Night Kid Brakes, Steering & Suspension 14 12-10-2002 03:28 AM
petty questions about Ground Control and KYB AGX Henry Brakes, Steering & Suspension 21 09-06-2002 12:48 AM
