Old 01-01-2003, 07:55 PM   #1
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default EJ25D vs. EJ253??
What are the differences in all of the EJ25 engine codes? also, Does anyone know if there is a difference in the ring around the crankshaft timing gear sprocket that the crank position sensor reads between a 2.5L and a 1.8L?? I am trying to run a 2.5 off a 1.8 ECU for awhile and need to know if I have to retain the 1.8 ring. I know the 2.5 has one with 15 teeth followed by a flat spot followed by 12 teeth then 2 more flat spots. I dont remember the 1.8 being like this but i cant remember too well. If someone has access to this info it would be a big help. thanks a ton for your help.
Hawk296 is offline   Reply With Quote
Old 01-01-2003, 08:04 PM   #2
outback2.5HO
Member#: 15135
95 GF WRX
Is your 1.8 ECU OBD II (96 and newer) or later? Curious to see how that would work.
Not sure on the tooth count, but I think the cam/crank angle sensors and plugs are different between the two.
outback2.5HO is offline   Reply With Quote
Old 01-01-2003, 08:13 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
my 1.8 is OBD I. I know the swap has been done on OBDII cars. It is a 95'. I have a few spare 2.5L wiring harnesses that are donating their electrical connectors for injectors ect. and ill probably just use my 1.8s temp sensor. I just dont know about the tooth count between the two. anyone know??
Old 01-01-2003, 08:21 PM   #4
outback2.5HO
Member#: 15135
95 GF WRX
The tooth count shouldn't matter, if the crank and cam angle sensors/connectors are from the 2.5. Is that a DOHC or SOHC that you are swapping in?
Old 01-01-2003, 09:59 PM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
It is a SOHC engine. My thinking was that ide use the 2.5 crank and cam sensors with whatever electrical connectors are needed. I thought that if the tooth count was different, even though the proper sensor is reading it, the ECU would not unterperet it properly.
Old 01-01-2003, 10:01 PM   #6
rhdude
Member#: 6637
2009 Acura MDX Sport
what engine management are you running to handle the Fuel delievery?
rhdude is offline   Reply With Quote
Old 01-02-2003, 04:58 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the 2.5 crank trigger has 6 teeth, at least on phase 2 blocks, i think phase 1's had 6 teeth as well but i am not certain. You can not change the crank sensor without some type of ecu. You need to retain the factory trigger wheels.
Jeremy
Old 01-03-2003, 12:46 AM   #8
Hawk296
Member#: 14555
1995 Impreza L
Baja
ok thanks for all of the help. EJ18 EJ22 Ej25 through 98 have same crank trigger. 99 has a differnt part number which supercedes all the others. I found out my engine was intended for a 2000 legacy manual trans. meaning it has the sprocket i described above which will NOT work on the older ECUs. The 2000 automatics have yet a different one which has 6 teeth. This is for the different ECUs/timing between the automatic engines and manual. I ordered the one for a 99 which I will put on and will be read by my 1.8L crank sensor and ECU just fine. hopefully that is the only problem besides switching other sensors/connectors.
EJ25D vs EJ252 vs EJ253 Chi_San Normally Aspirated Powertrain 35 11-27-2012 08:15 PM
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels Engine/Power/Exhaust 24 07-22-2010 10:23 AM
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels NWIC Private Classifieds 23 07-22-2010 10:22 AM
EJ251 vs EJ253 qtr_wrx Normally Aspirated Powertrain 10 11-24-2008 12:00 PM
ej25d or ej253 block? illegal2.2 Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-30-2007 02:08 AM
