Old 02-20-2001, 10:40 AM   #1
Die Civic
Member#: 3301
2001 RS
Post Who else gets back fire with an Apex-i N1?
Curious if this is normal, I know we run rich, but I get backfire all the time, is it the exhaust or is my piping slapping the rear diff making this noise?
Die Civic is offline   Reply With Quote
Old 02-20-2001, 10:42 AM   #2
25psi
Member#: 3086
2001 2.5 RS
Post
I hear ocasional rare backfire from my Stoumlong.
I think it is normal.
Eugene
25psi is offline   Reply With Quote
Old 02-20-2001, 10:57 AM   #3
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
backfiring is normal...
my N1 does the same too...
no problem with it what so ever....
dhouldn't worry too much about it...
laters
michael
Michael is offline   Reply With Quote
Old 02-20-2001, 10:58 AM   #4
bratmantlz
Member#: 3231
88 626 Turbo
white
Thumbs up
i will tell ya soon. i am getting one from imprezars.com N1 on my RS soo soon
bratmantlz is offline   Reply With Quote
Old 02-20-2001, 11:12 AM   #5
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
Post
What kind of gas do you use?
Kcz is offline   Reply With Quote
Old 02-20-2001, 11:36 AM   #6
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Question
are you sure that it is "backfiring," or is it a burbling type note when letting off the throttle/deceleration? i get the burbling sounds and it is pretty kewl i think.
justin
joostin420 is offline   Reply With Quote
Old 02-20-2001, 01:29 PM   #7
UCmego
Member#: 3446
Angry
If I hear this question one more time I'll SCREAM! Damit!! DONT YOU PEOPLE GET IT! IT IS SUPPOSED TO BE THAT WAY! It is the back pressure from the engine....it sounds awesome and it is NOT a MALFUNCTION! DUH!
UCmego is offline   Reply With Quote
Old 02-20-2001, 02:05 PM   #8
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
I feel just like UCmego (just not so violent).
Another thing, have you guys ever actually heard REAL backfire!? It sounds like a gunshot!! Nothing like what you hear out of our exhausts (unless there is something wrong with the car of course)!!
Strepto is offline   Reply With Quote
Old 02-20-2001, 02:24 PM   #9
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
aww cmon people he is just wondering if this is normal and is concerned. it may have been posted before but its always good to get a fresh perspective on things.
Old 02-20-2001, 02:25 PM   #10
Die Civic
Member#: 3301
2001 RS
Post
Okay mister car gurus, you don't gotta be so cocky about it, like you were all born with this knowledge, this is why its a QUESTION!
Old 02-20-2001, 02:32 PM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Lemme try and get technical here...
IIRC, the reason we are getting the burbling from a free flowing exhaust is because of the injector ontime. Because of the lower backpressure, the exhaust is clearing out faster and the engine able to move into the next stroke faster. The ECU is calibrated for a set fuel value based on certain criteria. Well since we have just changed that criteria with the exhaust, the ECU is no longer running all the correct numbers. You race up the tach, left off the gas to shift, the injectors put in a little too much fuel, and then on the next stroke you burn a little extra gas *insert burble sound here*. Or maybe it was the injectors pushing a little unburnt fuel down the exhaust. *shrug*
I think thats how that works, but its been awhile since I read about it, so I may be way off base here.
-Jon
Old 02-20-2001, 02:36 PM   #12
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
Hey UCmego...
Um, well...Settle Down, Beavis!
jlyttle is offline   Reply With Quote
Old 02-21-2001, 12:31 AM   #13
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
okay..it not actual backfiring..
it just sound like it....
this only happen when you are slowing down..
lift throttle and you will hear the pop pop pop sound... or when you are down shifting at a high rpm...
sounds pretty nice if you ask me....
laters
michael
Old 02-21-2001, 05:45 AM   #14
etam
Member#: 439
www
Post
Stimpy, are you saying that once I reset the ECU and let it to learn the new exhaust flow, the backfire will be gone IF there is one.
That's what I hear from my car last night. Got new cat-back and reset ECU and less burbling sounds now.
etam
etam is offline   Reply With Quote
Old 02-21-2001, 05:57 AM   #15
Dirty Underwear Gang
Guest
Member#:
Post
I have an N1 catback and the only time i get backfire is when my 02 sensor went bad... Otherwise it makes burbling sounds on deceleration which is totaly normal.
Old 02-21-2001, 08:42 AM   #16
Impy
Member#: 489
Post
I have an N1 with a custom midpipe and it DUS give teh occasional backfire... when it decels itd go... vrooooom, blurp blurp blurp BANG... blurp blurp...
Impy is offline   Reply With Quote
Old 02-21-2001, 10:11 AM   #17
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
The burbling may be reduced after an ECU reset, but they will not be completely eliminated.
Old 02-21-2001, 02:32 PM   #18
UCmego
Member#: 3446
Have a Nice Day?
"Settle down Beavis?"
Hey MF, how bout you get an original insult? I get tired of the LAME AZZ comments on this board. If the questions get any more stupid, then we might as well call ourselves: www.honda-acura.net
Example:
1. Auto vs stick?
2. Can I put VTEC on my Subaru (this one is the worst! go to the general forum and see it)
3. What should my next mod be? (I like to answer this one with: "a brain")
It is stuff like this that gets me fired up. We need a forum with an intelligence/experience scale...if you're too young, too dumb...go to www.honda-acura.net.
Old 02-21-2001, 08:32 PM   #19
Die Civic
Member#: 3301
2001 RS
Post
Then why don't you buy a honda, and become a member of the honda-club, and don't rag on hondas, are cars may be AWD, but i know some hondas that will eat your ride up, turbo'd or not. And YES, with curves on the road as well.
Old 02-21-2001, 09:15 PM   #20
RidinLow
Member#: 329
1995 325i
Arctic Gray
Question
Not to add fuel to the fire, but what the hell are you guys talking about? Just read my above post, it's the only correct answer to the original question.
RidinLow is offline   Reply With Quote
Old 02-21-2001, 09:52 PM   #21
5 Door Man
Member#: 2019
Post
Man-o-man...I used to get that way when people asked me questions like that. You have to realize not everyone knows as much about Subarus, or cars in general, as you do and encourage them to continue their interest by NOT giving them a bad impression of other enthusiasts. They want to learn, for godsake, man!! Don't stifle them!!
"There's no such thing as a stupid question, only a stupid answer"
5 Door Man is offline   Reply With Quote
Old 02-21-2001, 09:55 PM   #22
01 Black RS
Member#: 2770
Post
geez I think UCmego has PMDD... better get that checked out. Some people have basic questions that need to be answered don't knock em for it, I'm sure you don't know EVERYTHING.
01 Black RS is offline   Reply With Quote
Old 02-21-2001, 11:07 PM   #23
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
I donít know if itís just my car, but it had always burbled on deceleration (stock exhaust). Itís very muffled and subdued, but itís there.
I guess Iím going to have to expect that burbling to get a lot louder once the RalliSpec catback system gets installed.
Oh wellÖ
Ed.
edekker is offline   Reply With Quote
Old 02-22-2001, 12:49 AM   #24
etam
Member#: 439
www
Post
Please excuse my limited knowledge (today is my second day of life with an aftermarket cat-back exhaust). Is SAFC going to help reduce burbling by optimizing the fuel curve?
etam
Old 02-22-2001, 12:55 AM   #25
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It's not a backfire, it's the sound of the exhaust gases smacking each other in the unequal length headers.
Like Strepto said, if it was a real backfire, everybody would duck because it would sound like a very loud gunshot.
Leaning out the mixture won't help at all because it's not caused by a rich running condition.
If you do a search on this, you'll find that this has been discussed many times in more detail.
Getting back together with an Ex... How'd that go? *poll alert* skimmilk68 Off-Topic 27 04-17-2006 03:29 PM
Who else gets off on watching reporters get hit with flying objects? eurojax Off-Topic 4 08-29-2005 08:56 AM
Getting back together with an Ex MeddlingKids Off-Topic 8 05-22-2005 07:23 PM
Is it ever a good idea to get back together with an ex? Hamsterstyle Off-Topic 20 06-25-2004 01:58 PM
who else gets irritated with the hill holder clutch randolph-rs Forester Forum 34 05-05-2004 09:18 PM
