Old 01-01-2003, 10:38 PM   #1
atomicapples
Member#: 12626
02 2.5 rs
Default problem with battery relocation.
i was going to do my battery relocation to the trunk
but i came across a problem. there are to wires that go to the positive side of the battery.
1 is to the start and 1 i dont know where it goes, but it looks like it goes to accessories.
so if i wire the starter to the battery in the back, what do i do with the other wire?
i know its kinda hard to understand. but if you look at the wires, 1 is going to the start and the other has like a elbow to it.
someone hepl
thanks
tony.
atomicapples is offline   Reply With Quote
Old 01-01-2003, 11:26 PM   #2
hotrod
Member#: 14141
2002 Impreza WRX
Default main power supply line to system
If I understand your discripton, meaning the wire that goes into the wire loom. That is the main power supply line to the entire car via the main fuse box.
It feeds power to _ALL_ the cars systems.
You will need to run a lead to that connection as well.
Larry
hotrod is offline   Reply With Quote
Old 01-02-2003, 12:27 AM   #3
atomicapples
Member#: 12626
02 2.5 rs
what is the best way to split the wires?
Old 01-02-2003, 01:33 AM   #4
tdxflex
Member#: 13634
look up some car audio parts, there are distribution blocks (they also come in no-fuses configurations which you'll most likely use. i would use something that looks like this, don't need a brand name but you get the idea. unless you want to try to solder the wires, which IMHO won't really work that great with such a thick wire. I did it to extend my wire when i changed my battery terminals and it's working out alright i guess, i wouldn't recommend it though.
http://www.sounddomain.com/sku/STISTEE0
tdxflex is offline   Reply With Quote
Old 01-02-2003, 02:09 AM   #5
Ti-REX
Member#: 21741
LGT Limited Wagon +
WRB Wagon STI V7/8
Exclamation
I did this mod in my previous car and I made the mistake of not having a good enough ground. This helped my ECU to fry
I ended up using 2/0 gauge wires for power and ground from the front back (although 1/0 would have been OK). Note that you should always use the same size positive and ground wires. Since around 30 feet of wire is required to do the mod, I found that welding wire was the best quality/price you could find.
Just a thought
Ti-REX is offline   Reply With Quote
Old 01-02-2003, 10:07 AM   #6
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Any one have pics of the battery relocated and how everything was wired up?
I am going to be doing this. I plan on using some car audio wire and distribution blocks.
Did you guys run the wire inside the car or outside?
Need4Boost is offline   Reply With Quote
Old 01-02-2003, 11:51 PM   #7
atomicapples
Member#: 12626
02 2.5 rs
it would be better to rn the wire inside the car.
i dunno who it would be outside.
i will be doing it this weekend. i will post pics of it then.
problems with battery and the sort hdempsey Electrical & Lighting 2 02-19-2010 08:54 PM
problems with battery and the sort hdempsey South East Region Forum 1 02-19-2010 01:52 PM
problem with battery? J.Leonard Baja Forum 19 09-08-2009 08:42 AM
Weird Problem with battery power? STIRS Electrical & Lighting 1 10-21-2005 10:52 PM
Air flow meter problems with turbo relocation alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-19-2002 11:00 AM
