Old 02-20-2001, 11:44 AM   #1
Die Civic
Member#: 3301
2001 RS
Post Help me!
Hey, um well this is what happened, I was going down northern blvd, and there was traffic so I slowed down to around 10mph, and i threw it back into second gear, and WHAM a whole bunch of grinding jumping rattling happened! Is my tranny tainted??
Die Civic is offline   Reply With Quote
Old 02-20-2001, 11:58 AM   #2
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
you might have mis geared or mis time your gear..
your car should be ok...
just don't do it too much...
it normal to mis gear once a while...
laters
michael
ps: no need to worry about it unless your are grinding gears on a regular bases...
[This message has been edited by Michael (edited February 20, 2001).]
Michael is offline   Reply With Quote
Old 02-20-2001, 04:30 PM   #3
Matthew Nelson
Member#: 2174
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
Every once in a while, when I'm shifting into first gear, there is a nasty sounding "chunk" sound. I assume this is normal, but probably not too healthy for my Impreza.
Before anyone hollers at me for downshifting at too high of an engine speed, I should note that I'm not throwing my Subaru into first gear while traveling very fast. I couldn't say for sure at what speed I'm rolling, but it's never more than 10 - 15 mph.
Matthew Nelson is offline   Reply With Quote
Old 02-20-2001, 05:00 PM   #4
Die Civic
Member#: 3301
2001 RS
Post
i get like some kinda of grinding even when i clutch it all the way out, every gear gets it, hot or cold engine, and sometimes it's real hard to get into first and second.. anyone else?
Old 02-20-2001, 06:15 PM   #5
Die Civic
Member#: 3301
2001 RS
Post
bump
Old 02-20-2001, 06:38 PM   #6
Michael
Member#: 989
99 RS Turbo
Graphite Gray Pearl
Post
its normal that its hard getting into first if you are downshifting...you won't be able to get into first untill like 5mph to 0mph..
this is on normal driving...
when you are driving on a cold engine...(like in the morning...) you will have problems shifting into first and second...
this problem will go away once the car is completely warm or after 10-15 minutes of driving..
this condition is normal too..its the cold shutter from the clutches pressure plate...
hope this helps
michael
ps: if you are grinding every gear under normal driving (once the car is warm).. i think you should take it to the dealer for them to have a look, car should grind in every gear like you said...
Old 02-20-2001, 06:50 PM   #7
Die Civic
Member#: 3301
2001 RS
Post
it doesn't exactly grind, when i throw it into gear, it feels like im sort of forcing the gears into place or it feels like it's going to snap or break, like really really sharp throws.
Old 02-20-2001, 07:07 PM   #8
D-Rock
Member#: 3651
2001 2.5 RS Coupe
Post
I think the MT on my car just sucks. I only have 1500 miles on the car and it still doesn't shift smooth. I'm trying to figure out at what point do I stop using the break in excuse. I try to drive the car nice but it doesn't like it. I guess I can beat on it and hope it breaks under warranty.
D
D-Rock is offline   Reply With Quote
Old 02-22-2001, 05:58 AM   #9
philrb
Member#: 2547
Post
Downshifting into first is one of the hardest stresses a tranny can take. Make sure you match your revs if you do this. Better yet don't D-shift into first, it's way to low....in fact second gear is borderline.
As the saying goes...."...each downshift is one less upshift..."
I D-shift to third and rarely into second and never in to first.
FWIW
philrb is offline   Reply With Quote
someone help me pick a wheel color!!! wrxtuner570 Interior & Exterior Modification 26 06-03-2010 04:02 PM
Help Me, Help Me, Help Me! againstdan Newbies & FAQs 9 11-11-2005 11:26 PM
I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! Asinine Off-Topic 7 03-03-2005 01:33 PM
Help Me! Help Me Please! wrxxxappeal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-10-2003 12:14 PM
Help me/Help YOu/Help ME MichiganRS General Forum Archive 7 12-15-2000 09:54 AM
