Old 01-02-2003, 04:14 PM   #1
WRXIN
Member#: 15405
2004 STI
Silver/Gold - Team Blew
Default mysterious oil leak - need help
First my setup - no power-related mods at all, none. I have done some suspension work only.
So, I park my 2002 WRX (about 10k miles on it, three oil changes since new) in the garage yesterday after lunch. I come out a few hours later to move the car and there's a small amount of oil on the ground, about the size of a roll of quarters. Its engine oil I believe. The oil was located directly under the downpipe, right below the turbo. After jacking up the car to get a better view, I couldn't find any trace of the leak.
I haven't changed the oil for about a month, so its not from that.
Anybody ever heard of or had a problem like this? I'll probably endup going to the dealer and they will probably not find anything and send me on my way until it happens again. I really hate taking my car in...
Any help would be great.
-Mark
WRXIN is offline   Reply With Quote
Old 01-02-2003, 05:23 PM   #2
tdxflex
Member#: 13634
do you have the stock drain plug or a fumoto valve? and it could also be your tranny oil, have you gotten that changed recently?
tdxflex is offline   Reply With Quote
Old 01-02-2003, 07:54 PM   #3
IMPEXRALLY
Member#: 29120
03 WRX 5MT
WR BLUE
hey, check your power sterring fluid, I'm currently having my dealer cover the repair on that for oir leaking. I just bought my car though only 1500 miles on it. GOOD LUCK!
IMPEXRALLY is offline   Reply With Quote
Old 01-02-2003, 07:58 PM   #4
WRXIN
Member#: 15405
2004 STI
I've got the stock drain plug.
The oil appeared on the ground behind the oil pan.
Haven't changed the tranny fluid yet.
IMPEXRALLY - I guess is could be power steering but the fluid level is fine. Where is your leak?
The fluid on the ground looked just like engine oil but who knows.
I've read a few old threads where people talked about weird intermittent oil leaks. Anyone heard about that?
I'm afraid it might be turbo related. Does engine oil flow through any part of the turbo or near it?
Old 01-02-2003, 08:54 PM   #5
MisterX
Member#: 17275
2002 wrx wagon
wr blue
I think your oil line, from the turbo, may be leaking.
russ
MisterX is offline   Reply With Quote
Old 01-03-2003, 12:44 AM   #6
IMPEXRALLY
Member#: 29120
03 WRX 5MT
WR BLUE
These are the pictures I took when I found out my Power fluid is leaking.... and I am still waiting for subaru install the ordered parts under warranty. I would recommend put some white garbage bad or huge paper underneath the car when you park your car in the garage overnight. and try to find out where's actually leaking. Best when you just drove home from work or school, while the car is hot....
It worked pretty well for me...
Old 01-03-2003, 12:44 AM   #7
IMPEXRALLY
Member#: 29120
03 WRX 5MT
WR BLUE
These are the pictures I took when I found out my Power fluid is leaking.... and I am still waiting for subaru install the ordered parts under warranty. I would recommend put some white garbage bag or huge paper underneath the car when you park your car in the garage overnight. and try to find out where's actually leaking. Best when you just drove home from work or school, while the car is hot....
Old 01-03-2003, 12:08 PM   #8
WRXIN
Member#: 15405
2004 STI
Thanks for the input.
IMPEXRALLY: After seeing your power steering fluid I can be sure that mine is not a power steering leak.
rwallaesa: I'll check out the oil lines to the turbo.
Thanks.
I am taking the car in to the dealer tomorrow to have it looked at and I'll post the results.
-Mark
Oil Leak, need help wtyree Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-05-2009 05:18 PM
Mystery oil leak... please help! Nims Normally Aspirated Powertrain 6 07-21-2009 12:16 PM
mysterious coolant leak need help zero-d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-05-2007 07:35 PM
Mysterious Oil Leak, please help. C J Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-14-2006 03:35 PM
Slow but steady oil leak, need help. trilap5e Service & Maintenance 3 01-06-2003 02:42 PM
