Old 04-07-2001, 07:10 PM   #1
BongMan
Member#: 2399
2001 Impreza RS
Post another CE light. Help!
I'm not sure what's wrong with my car now. I started it up this morning and it seemed ok, then the engine revs dropped and a CE light came on. I turned it off right away because i panicted(?-spelling).
I did a ECu reset and it seemed ok but the revs were higher at idle. I'm not sure if it's hydro lock because it rained yesterday and i have a weapon R intake with open hood scoops. It could also be my crank pulley because i didn't put much grease on it. It could be my afc which i installed myself, but i've been checking all the conections and they seem fine.
i've tried starting it a couple of times and when i turn it off it rattles violently and the CE it still staring me in the face.
any suggestions are appreciated.
larry
BongMan is offline   Reply With Quote
Old 04-07-2001, 07:27 PM   #2
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Well, you're not hydro-locked. You couldn't get that much water into your engine from open hood scoops. However, if the WeaponR intake uses a foam filter, it could be water-logged and choking your engine.
gavin is offline   Reply With Quote
Old 04-07-2001, 07:36 PM   #3
BongMan
Member#: 2399
2001 Impreza RS
Post
i'm using a K&n filter so no foam. also i had my o2 sensor replaced before.
Old 04-08-2001, 02:15 PM   #4
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Post
Intialize your S-AFC i before i dyno tuned it it thought it was running right but then is started shooting black ***** everywhere and the CE light come on. Your probably just getting a overly rich reading. I have this problem when i use my Zex nitrous cause it cranks the fuel pressure...
Xscreamer is offline   Reply With Quote
Old 04-08-2001, 05:13 PM   #5
pimpomtic
Member#: 2699
2001 2.5 RS- ?????
Post
On, my car my CE light is on and off on and off I am not sure what's wrong with it. But for a couple of days it on then a few days it's off then it turn's on again. So I am not sure at all. I have a 2001 with cobb intake borla header and borla cat-back. Any suggestions?
pimpomtic is offline   Reply With Quote
Old 04-08-2001, 06:57 PM   #6
T-WReX 2.5RS
Member#: 5105
2000 Impreza
Post
pimpomtic...Did you do an ECU reset after you installed all of the mods you described? That MIGHT be a factor of why the CE light comes on. I had that happened to me when the car had 3k miles..came on and off like crazy, but it fixed itself and now everything is cool...????????
tony.
T-WReX 2.5RS is offline   Reply With Quote
Old 04-09-2001, 09:12 AM   #7
pimpomtic
Member#: 2699
2001 2.5 RS- ?????
Post
No I did not do a ECU reset I guess I should do that. How do you do that. In means reset the ECU?
Old 04-09-2001, 09:45 AM   #8
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
Post
to reset, take off the negative, positive, or both terminals from your battery for at least 30 minutes. then start your car and let it warm up on it's own meaning DON'T TOUCH THE GAS WHEN YOU START IT! i would wait a half hour for that as well to be safe. then turn the car off. then turn it back on again and do some spirited driving varying your RPM range throught the gears. that should do the trick.
as for you BongMan...do the simplest think...check your gas cap.. above that...good luck
trojan9x is offline   Reply With Quote
Old 04-09-2001, 01:29 PM   #9
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
Post
Pull out the guage cluster (how-to in i-club somewhere) and cut the wires for the CE. Viola! End of problem.
(of course I am not serious)
-Andy
RallyImprezive is offline   Reply With Quote
s-afc ,ce light help... hondaconvert Normally Aspirated Powertrain 14 06-27-2001 09:26 PM
Another CE light question BlackIce Legacy Forum 3 05-21-2001 11:40 AM
another CE light question, please dont flame me hondaconvert Normally Aspirated Powertrain 6 05-09-2001 07:55 AM
Another CE light mystery phantomdrain Technical Forum Archive 4 09-24-2000 02:10 PM
CE light... help Impy Technical Forum Archive 5 05-21-2000 11:51 AM
