Old 01-03-2003, 10:18 AM   #1
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Question Part throttle hesitation
Yes, I did a search.
So a couple of days ago, I noticed my STOCK WRX with just over 3,000 miles bucking a bit at part throttle. It didn't do this before. Does anyone have a link on this problem? Most of what I found on this was with modded cars.
It's hard to duplicate the problem too. Only 2 things have happened in the last week that make me think caused this. A) I changed my oil for the first time (highly unlikely) and b), I filled up with no-name 91 Octane rather than my usual 93. Other than those two things, I have no idea.
Can somebody please point me in the right direction? Thanks!!
MSD
merlot is offline   Reply With Quote
Old 01-03-2003, 12:48 PM   #2
KJR
Member#: 16879
it will usually do that even if you're still stock when the motor and turbo are cold. if it does it when the car is warmed up then you may have an issue with the ECU or the boost contoller. hope this may help....
KJR is offline   Reply With Quote
Old 01-03-2003, 12:54 PM   #3
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Thanks KJR!
Any links to were I could find out more?
MSD
Old 01-03-2003, 01:12 PM   #4
KJR
Member#: 16879
the only thing i could advise is to try searching for info here or take it to the dealer and see if they can diagnose a problem. i am not aware of all the changes they may have made to the new model as far as boost control or TPS settings in the ECU. sorry man..
Old 01-03-2003, 02:07 PM   #5
merlot
Member#: 16935
2012 Volvo S60 T5
2013 VW CC R-Line
Thanks again KJR. I'll try a few more searches. I'm not too concerned at the moment. If the problem persists, then I'll take it in...
MSD
Old 01-03-2003, 03:16 PM   #6
SJwrx
Member#: 14970
1997 GF8
multi
my dealer replaced a cat under warranty, saying that was the problem. Nope, from what I hear, it is either a part of the wastegate or the ECU screwing up.
Rich
SJwrx is offline   Reply With Quote
Old 01-04-2003, 09:13 PM   #7
toobluewrx
Member#: 4911
2002 Impreza WRX
MSD, check this thread.
toobluewrx is offline   Reply With Quote
On/Off throttle hesitation, cured by ecu reset Draken Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 09-29-2005 01:54 PM
Hesitation in part throttle MY03 Lancer3d Engine Management & Tuning 4 01-08-2005 09:29 AM
Part throttle hesitation with Ecutek? Equilibrium Tuning Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-30-2003 06:13 PM
Part throttle hesitation mod.... toobluewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 01-18-2003 01:06 PM
serious studdering when car lauches also throttle hesitation=>HELP AliBenn Normally Aspirated Powertrain 10 04-02-2001 08:46 PM
