Old 01-03-2003, 12:43 PM   #1
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Default STI springs from Rallispec... any reviews?
as a general rule, I dont replace springs without replacing struts. However, I do not think the factory struts on the WRX are that bad. I would like to stiffen up the ride a tad and perhaps go for a bit of lowering. Rallispec sells STI springs that are "designed to work with factory struts"
Anybody tried these? Any premature wear on the struts?
Thanks for any help!
SCRAPPYDO
stephen
SCRAPPYDO is online now   Reply With Quote
Old 01-03-2003, 02:02 PM   #2
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
I just installed STi V7 Springs (for the wagon) that I purchased from Rallispec. They are not supposed to lower the car (I haven't measured since I am letting the car settle still), but it doesn't appear to be any lower.
So far I am real happy with them (2-days installed). It's been wet and yucky up here so I haven't tried any "g-force" runs, but ride comfort is much better than I expected, dare I say better at low speeds (25-30 mph on local crappy roads up here in Boston). Please note I am running Koni adjustable inserts in stock WRX wagon strut housing though. The Koni inserts are a bit more stiff at the "softest" setting than the stock struts where.
The part numbers for the springs I have are:
Front = 20330 FE130
Rear = 20380 FE680
Spring rates are 200 lbs/in front, and 190 lbs/in rear (appoximate rates, I don't have any hard data to back that up, just what I was told), which is comparable to the STi sprort spring set I think (but that Sport springs lower the car).
Hope this helps. If you have any questions, fire away.
Paul G.
paultg is offline   Reply With Quote
FS : STI Springs from a 2007 theendxofanera SCIC Private Classifieds 0 06-01-2010 02:29 PM
MY08/09 STI springs from Prodrive ??? Petrie Brakes, Steering & Suspension 9 06-13-2009 04:55 PM
FS: STI Springs from 2005 Bimmubishi NESIC Private Classifieds 0 04-06-2008 10:33 PM
FS: OEM STi Springs from an '04 $50 OBO ldc6 Mid Atlantic Impreza Club -- MAIC 5 08-10-2005 01:54 PM
