Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 02-20-2001, 06:47 PM   #1
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Question Need help with me S-AFC settings???
I need to know the recommended settings for a MY99 with Minnam Intake, Zex Nitrous, N1 muffler with 2 1/4 piping, Zex spark plugs, and a Unothrodox Racing Pulley....
I also need to know the recommend settings for a MY99 without the aftermarket intake and nitrous...
~Brandon
Xscreamer is offline   Reply With Quote
Old 02-20-2001, 10:50 PM   #2
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
Do a search for how to tune with the S-AFC and make your own settings. This will be the only accurate way of properly fueling your engine.
Sean
Sean McElderry is offline   Reply With Quote
Old 02-20-2001, 10:51 PM   #3
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Yep, there's no AFC settings that apply to all cars. You need to tune it yourself, especially since you have NOS.
RidinLow is offline   Reply With Quote
Old 02-21-2001, 09:13 AM   #4
cvalle-sd
Member#: 420
2001 Cr-V
Post
Not for nothing, but EVERY time, since the S-AFC came to this forum, that the subject of tuning comes up - a search is advised, but I've seen most if not all of the previous AFC posts, and the info isn't there. I have mine tuned for a progressive richening from 4000rpm - >, peaking at +10-15%, depending on the grade of fuel I'm using. I don't think anyone has any dyno pulls with the AFC - at least not that they're talking about. The problem was/is that Shiv Pathak talked about the AFC when SCC's Impreza was N/A, and the lean-run caused by a tube intake was what needed correction. There was no tuning done with a stock intake, stock plumbing/Cone filter, etc. Then TECII came along, and the AFC/ITC fell into poor favor - unless you already sank $700 into them,and were kinda stuck...Guess where I am? I am getting pretty good results with a K&N cone filter running into the stock plumbing, and a 60mm cat-back, among other things. But exactly how well, and how far I am from the ideal is a whole other thing. If you learn anything new, share the wealth.
cvalle-sd is offline   Reply With Quote
Need help with injector pulse width settings LiquidForce Commercial ECU Reflashes 2 08-13-2006 03:21 PM
Need help with Greddy e-01 Settings Fahd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-15-2004 12:50 AM
Need help with Blitz SBC-iD settings Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-29-2002 06:37 PM
need help with Apexi s-afc wrxwagon2.0t Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-08-2002 07:28 PM
need help with my super afc the spacecowboy Normally Aspirated Powertrain 3 12-07-2001 05:19 PM
