Old 01-03-2003, 02:59 PM   #1
BuddhaSac
Member#: 29834
6 HP Ford Model T
Color = See Through
Default Before I Install These Borla Headers...
Anyone have any advise?
I've been soaking the problem areas in WD40 for the last two days.
I wanna get some replacement bolts in case i have to cut that PITA one connecting the stock header to cat. Anyone know the size of this bolt.
Also what type/size wrench would you reccomend?
Thnx in advance
BuddhaSac is offline   Reply With Quote
Old 01-03-2003, 03:20 PM   #2
Frakk's2.5
Visiting NASIOC Timeout
Member#: 11181
1- No need to spray your problem areas with WD40 for two days
2- you will not need to cut your anything on your car
3- 12mm,13mm,14mm is all that you will need
Then I again I have a 01 RS so I'm not too sure how different it will be since you have a different cross member than I do...but it wasn't hard at all for me to install it considering that it was the first time I did a major install on my car, once you put the headers on you well get some smoke (at least I did) coming out of the engine I did the same thing I soaked the trouble places with WD40 prior to the install but after it all dried up no smoke at all enjoy you will like the sound boxer sound that scoobs are known for...
Frakk's2.5 is offline   Reply With Quote
Old 01-03-2003, 08:10 PM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
I drilled out the holes a little bit the second time I put them on.. made them go on alot easier to put on. You need a 14mm deep socket for the engine nuts on the studs.
rhdude is offline   Reply With Quote
Old 01-03-2003, 11:29 PM   #4
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
Agreed drill the holes out a little after you see where there going to be tight and it will make your life alot easier.
Poppa smurf is offline   Reply With Quote
Old 01-04-2003, 01:00 PM   #5
dcoty
Member#: 3149
01 V7 GC/R32 sky
Be careful when removing the stock headers and putting on the new ones as to not damage any of the threads on the bolds of the engine, you need a good seal there.
Dan
dcoty is offline   Reply With Quote
Old 01-04-2003, 01:03 PM   #6
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
I don't think this will be a problem on such a new car, but on the older cars for sure. The studs like to come out with the bolts (rusted on to know return) on the flange that mounts to the head. Thats not really a problem but since some of the holes have different depths, if you dont put the same studs back in the same holes some of them won't tighten all the way and your header can litterally rattle.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 01-04-2003, 02:40 PM   #7
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Make sure you use the correct size wrench. I found out from experience that I can't really get the socket seated all the way on the bolts by the cat. So I use 2 wrenches to take that off. 14MM is the size I believe. Other than that its a peice of cake, you'll love them.
AndyM is online now   Reply With Quote
Old 01-04-2003, 09:23 PM   #8
BuddhaSac
Member#: 29834
6 HP Ford Model T
Color = See Through
Well I did it. I'm sore and tired, a few scratches and cuts. The bolts near the cat were 14's. I now back everyone who said it would be a PITA, I back them 200%!!!! I only have 13k on the car and one of the bolts were rusted SHUT, I mean together! So I ended up breaking it in half (on accident) but I replaced it. And yes I had to drill the holes cuz they just wouldn't fit. I actually pushed them far enough in to catch the thread of the bolt and inched them up slowly until they sat nicely. It sounds different than I expected, I CAN hear each individual engine pulse, it does sound kinda like a harley (somewhat). I am satisfied I drove it avbout 25 miles and no CEL, although a premature assessment, it is a good sign Sounds MEAN
And thanks for the info, it really did help a lot, really.
Old 01-04-2003, 09:29 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
sweet! So what are your opinions on they headers? any power gains?
DoctorNick is offline   Reply With Quote
Old 01-05-2003, 01:58 AM   #10
diediemyscooby
Member#: 19140
2000 Impreza RS
what should i torque all these exhaust bolts to when i go to install these?
diediemyscooby is offline   Reply With Quote
Old 01-07-2003, 02:23 AM   #11
diediemyscooby
Member#: 19140
2000 Impreza RS
Can i kill a thread or what?
Old 01-09-2003, 12:41 AM   #12
diediemyscooby
Member#: 19140
2000 Impreza RS
k... ill just make em real tight like
Old 01-09-2003, 01:50 AM   #13
dRu888
Member#: 8305
2001 2.5RS
Gunmetal
glad it went in good Buddha. hopefully worth the effort
dRu888 is offline   Reply With Quote
Old 01-09-2003, 11:37 AM   #14
BuddhaSac
Member#: 29834
6 HP Ford Model T
Color = See Through
Yeah it was worth the effort. And most thanks to you for selling those headers to me. You don't know how much I HATE dealing with shipping, too many bad experiences. I'm actually still trying to get used to the sound. My wife keeps telling me "there's a motorcycle behind us", I keep telling her "no, its OUR car"
Old 01-09-2003, 04:03 PM   #15
BuddhaSac
Member#: 29834
6 HP Ford Model T
Color = See Through
I have a question.
The front of the car now smells strongly of gas when I first start it up and it backfires a lot (from the headers and the muffler). Should I be concerned about either of these? I've checked for any exhaust leaks and found none. Thanx
Old 06-27-2003, 10:45 AM   #16
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
What gaskets, springs, and bolts will I need to replace my stock headers (from MY 02 RS 4EAT) with the Borlas?
I'd like to know what I need to pick up from the dealership. Part numbers are helpful as well. Thanks!
(Btw, BuddhaSac, you're most likely running very rich as a result of your intake/exhaust mods. Subaru's are known to run rich stock, but increasing airflow into the engine makes it even worse! It's a common problem, but it doesn't hurt anything but your mileage)
DrBoy01 is offline   Reply With Quote
Old 06-27-2003, 02:49 PM   #17
goobie
Member#: 8273
2006 WRX Wagon
You'll need 2 exhaust manifold gaskets (fit between block and header) and 1 gasket from the header to the cats.
I don't know the part numbers but an part guy worth his/her salt will be able to get you the right parts based on that description.
Chad
goobie is offline   Reply With Quote
Old 06-27-2003, 03:22 PM   #18
hellopat
Member#: 6606
2002 Impreza RS 2.5
BRP
I've been driving with the borla's for 50 miles or so and i came up the the CEL . I reset the ecu and it came back on again after 30 miles or so. Not sure what to do. I guess i'll try to put some miles on it and see if it doesn't go away by itself.
hellopat is offline   Reply With Quote
Old 06-27-2003, 04:55 PM   #19
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Power gains?
What are your impressions after this mod? Inquiring minds need more anecdotal evidence.
Compressed is offline   Reply With Quote
04 wrx early production- Harmonic dampers?? anyone install these before?? MAtwal Transmission (AT/MT) & Driveline 10 01-09-2010 01:29 PM
Installed my Borla header, with 3" exhaust back on my NA 2.2 reddevil Normally Aspirated Powertrain 3 04-28-2008 12:33 AM
any forester guys ever install a borla header on a N/A subaru with an oil cooler? Big_Hitter Forester Forum 10 03-04-2005 04:39 PM
Install Pics - Borla Headers Skylab Normally Aspirated Powertrain 102 01-25-2004 11:16 PM
98 GT Wagon Borla Header Installed Scooby2 Legacy Forum 8 02-01-2001 04:38 PM
