Old 01-03-2003, 04:26 PM   #1
i-rex
Member#: 11372
Question EMI surging in 1st gear
Hi all,
For those with the EMI adapter, are you folks experiencing surging in 1st gear from 1500 to 3500 rpm's? I can do this repeatedly. Leaving the line at about 30%, the car surges like it's trying to buck you off. Not so smooth and attracts attention in the wrong way. I've noticed when I slip the clutch slightly to @2000 rpm the surging disappears.
However, from 3k rpm's and up it seems very smooth from 3rd gear up. So it seems to have solved the common surging but now has caused a surge in 1st. I'll triple check the wiring.
i-rex
stage 0
EMI adapter
i-rex is offline   Reply With Quote
Old 01-03-2003, 04:31 PM   #2
Member#: 13004
2002 Pump Gas Homo
I think shiv has addressed this and the use of an alternate jumper should probably be tried on your car. Give him a call and see for sure though. Mine had a similar problem that was in fact a loose throttle wire going to the throttlebody. dont know how that happened as I never monkeyed with it but the EMI made my car super smooth
David@Vishnu is offline   Reply With Quote
Old 01-03-2003, 05:37 PM   #3
i-rex
Member#: 11372
MP5-Thanks for the tip... I talked to Shiv and I shouldn't have had any links installed. I prevously had it on "LK3" now without it it runs much smoother. Thanks Shiv...
i-rex
Old 01-03-2003, 08:29 PM   #4
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Glad to hear it!
shiv
Vishnu Performance is offline   Reply With Quote
Old 01-03-2003, 09:23 PM   #5
02 T-WREX
Member#: 11449
2006 STi
SGM
So Shiv... should we not use any of the jumpers? I read the instructions and put the jumper on Link3 because I figured I might as well keep the fuel cut (stock turbo)... I haven't had any surging... but should I take the jumper off or what?
Thanks,
Chip
02 T-WREX is offline   Reply With Quote
shuttering in 1st gear? limshady88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-08-2015 05:41 PM
In 1st gear, yet shifter is in neutral?? hipnotik978 Transmission (AT/MT) & Driveline 5 01-09-2007 05:35 PM
In 1st gear yet shifter is in neutral.. hipnotik978 Transmission (AT/MT) & Driveline 2 01-08-2007 07:46 PM
Loud clunk sound from rear when pressing in clutch at 5k rpm in 1st gear Ging Service & Maintenance 7 08-17-2002 02:26 AM
Legacy auto problems in 1st gear? MrSwede Transmission (AT/MT) & Driveline 2 09-05-2001 11:46 PM
