Old 01-03-2003, 04:08 PM   #1
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Default grip vs. pickup dilema
so i'm debating about the following setup for shoes this season(SM):
1.) 16" Rota Slipstream
225/50/16 (haven't decided on what R rated tire yet)
or
2.) 17" ROTA SDR
245/?/17
so i figured i get i can pickup speed faster our of the corners using the 16"... but then again i'll be able to carry more speed through the corners using the 245s... rite?
any suggestions folks?
suby_dude is offline   Reply With Quote
Old 01-03-2003, 05:01 PM   #2
rex n effect
Member#: 15289
02 wrx sedan PSM
& grey '11 TDi daddywagon
Did you get rota to make the SDR in 17x8? If you could get them to make a 17x8 wheel, you might gain more than a few customers.
rex n effect is offline   Reply With Quote
Old 01-03-2003, 05:03 PM   #3
suby_dude
Member#: 17397
WRB, White
to make a custome wheel i need atleast 50 of those customers to even be worth making those.
Old 01-04-2003, 04:09 AM   #4
rex n effect
Member#: 15289
02 wrx sedan PSM
just curious,
because it's definitely not recommended to put a 235 or 245/40 R17 tire on a 7.5" wheel. You should get a 17x8
Old 01-04-2003, 09:44 AM   #5
zzyzx
Member#: 815
2013 Boss 302 White
2000 2.5 RS Coupe Silver
The WRX needs the OEM or smaller not to kill the gearing. Put 245/45s on your 16s and have fun.
- Steve
zzyzx is offline   Reply With Quote
Old 01-04-2003, 09:45 AM   #6
HoRo1
Member#: 15618
If you get a 245/40/17 or better still a 245/35/17 to fit go for it. Is there even an R compound in a 245 size? There is no way that a 245/45/17 or even 235/45/17 will help because the WRX gearing is too tall as it stands and such a big wheel will make it worse. I'd favour going as wide as you can fit with the lowest sidewall height available for that tyre width. Of course, you'd have to get an rim that is at least 8" wide.
HoRo1 is offline   Reply With Quote
Old 01-04-2003, 11:30 AM   #7
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
- Steve
Joe,
I agree. Kumo and Toyo make a 235/40/17 R compound tire. These will fit perfectly on the 17x7.5 rims that you provide.
I ran the 225/50/16 and because of the gearing issues, I often lost time coming out of the corners.
Here is an interesting comparision:
Stratos, velolexus, and myself were comparing one course, our first event in the slush at oakland with that long ass straight.
Stratos was running 225/45/17, velolexus was running 215/50/16, and I was on my 225/50/16
At the end of the straight here is where we were in the gearing
  • I was barely at the redline
  • Stratos was in the redline but not on the revlimiter
  • Velolexus was bouncing off the revlimiter
ChrisW is offline   Reply With Quote
Old 01-04-2003, 12:52 PM   #8
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
- Steve
Hey Steve, have you done this yourself? This is similar to what I was thinking about, but I was wondering if 245 tires such as Yokohama AVS ES100 or Kumho 712 would fit on 16 inch rims. Also the car will ride lower and the speedometer, and odometer will read wrong, won't they?
Tom
thoughto is offline   Reply With Quote
Old 01-04-2003, 03:55 PM   #9
zzyzx
Member#: 815
2013 Boss 302 White
No, I compete in STS, no Rs allowed. However, many ppl competing at Nats last year had 245/45-16s mounted on the stock 6.5" wheels.
- Steve
Old 01-04-2003, 05:03 PM   #10
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
I kind of blundered my way into this thread, not noticing it was on a motorsports forum. I guess for road driving 245/45-16 might be too radical - did anyone try something like this for day to day summer driving?
Old 01-18-2003, 06:13 PM   #11
NightmareOnSubySt
Member#: 1352
2005 Forester XT
black
Steve, did they mention any negative wear issues running such a wide tire on a narrow rim? Did they even care? Were they using spacers? Thanks.
Russ
NightmareOnSubySt is offline   Reply With Quote
Old 01-18-2003, 11:24 PM   #12
HoRo1
Member#: 15618
I would choose to carry more speed into, through and out of a corner rather than sacrificing the above for slightly greater acceleration out of same corner.
Old 01-19-2003, 12:13 PM   #13
zzyzx
Member#: 815
2013 Boss 302 White
No.
I don't know.
- Steve
Old 01-20-2003, 09:47 AM   #14
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Are you talking about suby's at the 02 nationals?? who was this?
There is absolutely no harm or anything fitting a 245 or 235 on a 7.5" wheel.
Kumho makes a 235/40/17 in the ecsta and a 245/45/16 in the victoracer. I would lean towards the 235 as that *would* provide a bit of a gearing advantage and wouldnt be much thinner then the 245/45
-Tom
trhoppe is offline   Reply With Quote
Old 01-29-2003, 01:50 AM   #15
thechickencow
Member#: 16840
07 fsxt
03 ktm 640 adventure
Chris,
Do you think that your entry/exit/line were exactly the same coming into and out of the previous corner and straight? Are the cars otherwise exactly equally modd'ed? I'm not debating that the wheels can make the difference, but I think that there may be too many other variables for this to be a good comparison.
All,
Has anybody run wider than 225 on 16x7s for daily driving? I'm considering some slipstreams currently, and would like to go wider if possible, but obviously don't want to have issues daily driving with rubbing and what not.
Jay
thechickencow is offline   Reply With Quote
Old 01-29-2003, 02:56 AM   #16
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
I would go with the Slipstreams with 225 R-compounds. I would run slipstreams with falkens for ST-X if I could afford spare wheels/tires...
Old 01-29-2003, 10:05 AM   #17
suby_dude
Member#: 17397
WRB, White
that's exactly what I ended up getting.
i put on the Kumho v700 on the slipstream.
I ran it this past weekend w/ my new wheels and my new NEW MODS
Old 01-30-2003, 02:57 AM   #18
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Hehe, can I borrow them for an autocross or two? LMAO!!!
Dilema - 2.5RS Vs 9-2x Aero xanVu Newbies & FAQs 4 01-26-2010 09:20 AM
GRIP - VW TH2 vs. Porsche Cayenne Turbo S AVANTI R5 Non-Subaru News & Rumors 7 10-02-2009 01:38 AM
if you guys had to buy a pickup truck? tundra vs f-150 vs tocoma vs frontier? enozto Off-Topic 34 04-24-2003 02:40 PM
hmmm, dilema dilema gavin Legacy Forum 9 04-03-2001 12:54 AM
Traction vs. Grip Subaman General Forum Archive 11 05-11-2000 09:18 AM
Message Board Statistics All times are GMT -4. The time now is 07:51 AM.
