Old 01-03-2003, 08:35 PM   #1
Bumsarama
Member#: 3137
2005 STi
WRB Nukabe/Cusco/Carbotec
Default Fidanza Flywheel?
Since the Fidanze Flywheel weighs 9.8lbs, is that too light to go? Will I notice a difference between this one and the other aftermarket flywheels which are usually around 12-13lbs? Is there a quality difference also? I am really interested in purchasing the Fidanza one and will appreciate any feedback.
Bumsarama is offline   Reply With Quote
Old 01-03-2003, 09:03 PM   #2
aj's25rs
Member#: 30160
9900 2.5rs
rbp,srp
i have a act/fidanza in my99. it allows you to rev up faster but its downfall is you have to keep the revs up. i mean if you normally take off from a stop at 900rpms then you would have to bring them up to like 1000rpms or a little higher. you also have to rev match on down shifts. once you drive past the break in point youll be fine. just takes alittle to get used too.
aj's25rs is offline   Reply With Quote
Old 01-04-2003, 05:31 PM   #3
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
I have cluthcmaster stage 3 and fidanza, what aj's25rs said is completely true. Also i lost a lot of top end power since the flywheel went in, I think it is in fact too light, but now i am paying the price.
My car revs really fast up to third gear, but just after i hit fourth or even in third I start loosing power and yuo notice the car is not advancing the same way. Even when i drag or street race someone, people that i used to be able to hold up to after fouth gear, pull away from me a lot faster than they used too. But also the car is hell a lot faster in the first tree gears.
P.S
I also have N1 light weight pulleys, wich i am planning to replace for the stock ones in the next week, to see if i can feel any difference
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 01-04-2003, 06:01 PM   #4
watcher in the sky
Member#: 3513
1997 Legacy Outback
so i wonder how much hp it would take to correct that loss of topend power? sure 40 more would do, but i wonder how little hp you could add to regain?
watcher in the sky is offline   Reply With Quote
Old 01-04-2003, 06:44 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
ummm, i lost no top end, my top end is stronger then it's ever been, you lose bottom end torque but gain HP.
Jeremy
Old 01-05-2003, 02:25 AM   #6
Member#: 5354
I dont know, maybe it is because the flywheel is so light, and I also have light weight pulleys. I will remove these next week and replace them for the stock ones to see what results do I get
Old 01-05-2003, 02:59 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The only possible effect of a lightened flywheel (or aluminum flywheel) is that the engine will rev more freely. I don't understand how a lighter flywheel could possibly cost you top end power.
I have a Fidanza flywheel on my car along with a Clutchmasters Stage 1 clutch. It pulls strong to redline, both by the butt dyno and based on actual chassis dyno pulls.
I stalled the car the very first time I went to put it in motion after having the clutch and flywheel installed - a combination of the grippier clutch and lighter flywheel, I'm sure. That's the only time I've ever had a problem. I honestly haven't noticed that I need to use more revs to get the car rolling.
I have noticed that it's a lot tougher to cruise slowly at low RPMs - like when you're creeping along in 1st gear in traffic. With the stock setup I could get down to 800-1000rpm if I was real gentle with the gas pedal. Now I can't get down below about 1200rpm or so before the car will start bucking - the engine is more responsive to throttle input and it just gets too hard to finely control the gas. I think the effect is compounded by the fact I have pretty extensive engine mods - I think the ECU has a hard time handling the added air flow with the throttle barely open, but that's just a semi-educated guess.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 01-05-2003, 05:06 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
pat to be honest i think they think it's slower because they are using the powerband to 6250 more since it's much easier to get to, for an RS w/o cams revving to redline is useless i shift by 6k because well anything above that is just crappy, the cams are screaming for dear life in a SOHC car.
Definitely no top end loss here.
jeremy
p.s.: Fidanza 9.6lb flywheel w/ ACT street clutch
Old 01-05-2003, 05:08 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Pat Olsen
oh yeah and BTW i am 100% with ya on that one, a hard to drive smoothly car becomes even MORE hard to drive smoothly
Jeremy
Old 01-05-2003, 04:16 PM   #10
watcher in the sky
Member#: 3513
1997 Legacy Outback
I kinda thought that momentum loss would be a factor, if you didnt rev match. because the rpm's would drop off faster and therefor, if you are not shifting properly, you would lose ground in the higher gears...right? atleast moreso than a stock set up.
Old 01-06-2003, 01:18 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
no, when you up-shift you aren't losing momentum.
Jeremy
Old 01-06-2003, 11:58 AM   #12
watcher in the sky
Member#: 3513
1997 Legacy Outback
I am talking about the flywheel, and how it would lose momentum.
Fidanza flywheel install? kaos200 Transmission (AT/MT) & Driveline 10 07-11-2009 12:50 PM
ACT Flywheel or Fidanza flywheel? Diversion Transmission (AT/MT) & Driveline 10 09-10-2004 01:23 PM
Has Anyone Had Any Trouble Fitting the Pilot Bearing for Fidanza Flywheel? BigElm Transmission (AT/MT) & Driveline 7 05-07-2002 03:44 AM
Fidanza flywheel and GFB underdrive pully kit- safe to use both? JSiwek Transmission (AT/MT) & Driveline 1 04-17-2002 01:29 AM
Fidanza Flywheel & Unorthodox UD pulley! Good or Bad imprezawd Normally Aspirated Powertrain 9 01-11-2002 08:11 PM
