Old 01-04-2003, 10:25 AM   #1
S-1
Member#: 10842
07 2.5i Wagon
Default Turbo missing oil and coolant feed lines?
Quick Question:
I have just purchased a turbo, but it is missing the brass colored oil line and coolant line. Can I use the parts from another bolt on turbo for my new turbo?
The hole where the oil line goes looks like it's threaded and the new line might just screw in. But the hole where the coolant line goes doesn't look threaded (but has two smaller holes on the side that are threaded) , so does the brass fitting just pop in there or what?
just wanted to find out if there is anything that i can do before taking the old turbo off first.
thanks
S-1 is offline   Reply With Quote
Old 01-04-2003, 10:51 AM   #2
PunksWRX
Member#: 5504
2004 Impreza WRX STi
I just received my VF-30 from Gruppe-S and it had the coolant lines already attached to the turbo. Maybe you can use the fittings off the stock Mitsu turbo. What kind of turbo did you pick up? The oil line on my VF-30 is just blocked off and you should use your existing oil banjo bolt and copper washers. Just be very careful not to overtighten these. They don't need a whole lot of torque.
Punk
PunksWRX is offline   Reply With Quote
Old 01-04-2003, 04:35 PM   #3
S-1
Member#: 10842
07 2.5i Wagon
Punk
It's a PE1818. So I could use the oil and coolant fittings off my VF30 then?
Old 01-04-2003, 04:44 PM   #4
PunksWRX
Member#: 5504
I'm not sure but I would assume so since the PE series are based on IHI turbos.
Punk
Old 01-04-2003, 06:12 PM   #5
Jan Shim
Member#: 6366
1998 WRX Wagon (Ret)
Power Enterprise ships both PE1818 and PE1820 with pre-fitted coolant and oil pipes. I once bought a used IHI VF24 turbo that had no pipes so I used the ones from the stock TD04L .. they fit. Similarly, get yourself a set of pipes from either your stock turbo or IHI. The banjo flange has a gasket -- use a new one!
Jan Shim is offline   Reply With Quote
FS: EWG Dump Tube (straight), Replacement turbo oil and coolant lines with washers ScoobyNubieToo! Engine/Power/Exhaust 10 02-15-2009 07:26 PM
Oil and coolant lines Chi_San Service & Maintenance 1 08-23-2008 11:13 PM
whats the diameter of coolant feed line to the turbo? dvang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2006 11:11 AM
used vf30 without oil and coolant lines - can i use stock lines? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-09-2004 10:17 PM
oil and coolant lines scoobyimprza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2003 12:01 PM
