Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 02-21-2001, 11:43 AM   #1
Spectre23
Member#: 311
2013 STi
CBS
Question O2 Sensor Voltage
I know this has been covered but I did a search and couldn't find it.
I have an AFC with the input 2 on my O2 sensor. Unfortunately it is on my rear O2 sensor. What voltage do I want to see on that O2 sensor. Also, is higher voltage richer or leaner? Currently I am seeing about .65v and my exhaust smells like crap telling me it is rich. Is the front O2 sensor a wide band sensor on all RS's or just 2000 and newer?
Spectre23 is offline   Reply With Quote
Old 02-21-2001, 11:48 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Only MY00 & up cars have the wideband sensors. .6x is way too rich... I think you should be seeing .8x, but don't quote me on that.
RidinLow is offline   Reply With Quote
Old 02-21-2001, 05:50 PM   #3
the spacecowboy
Member#: 765
Post
afc....o2 sensors....the super afc is hooked to the o2 sensors?...what wires are these...
or the wires going to the ecu are o2 sensor wire...
sorry for the stupid Q
space
the spacecowboy is offline   Reply With Quote
Old 02-21-2001, 07:22 PM   #4
Spectre23
Member#: 311
2013 STi
CBS
Post
I beleive they call it the "Blue Wire Mod". It is an optional connection you can make with the wire that would go to the second mass airflow sensor on a Supra. I don't know if it goes to the ECU or the wire itself, I didn't wire mine.
Old 02-22-2001, 12:24 AM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
The wideband O2 sensor is only on MY00+. Anything before that has the standard narrow band O2 sensor with readings of 0-.9v. Higher is richer as I recall. I would recommend relocating your A/F readings to the front O2 sensor. Often the rear O2 sensor will read leaner than the front O2 sensor because of the cats.
-Jon
Old 02-22-2001, 04:31 AM   #6
philrb
Member#: 2547
Post
At idle you should get fluctuating voltage from about .3 to .7 (the fluctuating aspect is more important than the actual voltages). When you open the throttle and hold it open to about 2k rpm the reading should go down for a moment and then up over .5 and then stabilize around .5.
The engine must be HOT as the O2 sensor does it's job at about 700 degrees F.
If you do take it out and it's cruddy looking you can salvage it by cleaning it off with a stainless steel brush. When installing DO NOT use silicone (dielectric)grease (the glop used for the other engine bay connectors). This'll add impedance and throw the voltages off.
If you still have problems run the car at legal speeds at 4500 rpm for a few minutes and then re-check your voltages. If you do buy a new sensor make sure it's Bosch.
philrb is offline   Reply With Quote
Old 02-22-2001, 06:21 AM   #7
Spectre23
Member#: 311
2013 STi
CBS
Post
Is that .5v for the front or rear sensor? Sounds like maybe the rear.
Monitoring the front o2 sensor voltage trhoppe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2002 11:13 PM
Anyone know O2 sensor voltage -> A/F ratio? Drews_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-19-2002 11:07 PM
O2 sensor voltage reza01 Normally Aspirated Powertrain 4 07-23-2001 01:12 PM
Front and rear O2 sensor voltages? Anybody get a reading yet? delectron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-12-2001 04:09 AM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 02:26 PM
