Old 02-21-2001, 01:34 PM   #1
the spacecowboy
Member#: 765
Post not a exhaust leak then what?
i went to midas cause i thought i had a exhaust leak....well it wasnt....i now have this hissing sound from the driver side....the guy said it sounds like a vacumm leak....i dont know what it is.....
all i know is i can hear air rushing out and can hear my valves....
anyone know....also if you do how to fix the prob...
i was told to take it to the dealer but i think if they pop the hood and see the nitrous, no fix for free...
thanks,
space
the spacecowboy is offline   Reply With Quote
Old 02-21-2001, 05:47 PM   #2
the spacecowboy
Member#: 765
Post
bump
Old 02-21-2001, 05:52 PM   #3
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
well a vacumm leak cant be to hard to find go in the engine and find all the hoses and check em ALL look for cracks with the engine running. be very very detailed with checking every hose. see how they look cracked or ripped or just broken. see if that helps if its a vacumm leak with a hose get a replacement from autozone and bam your good to go.
Brian
bratmantlz is offline   Reply With Quote
Old 02-21-2001, 05:56 PM   #4
the spacecowboy
Member#: 765
Post
ok....but one prob...i have no idea where the vacumm hoses are...
sorry....
thaks,
space
Old 02-21-2001, 05:59 PM   #5
bratmantlz
Member#: 3231
88 626 Turbo
white
Thumbs up
just look around the hoses that go to the intake and off of the cylinder tops and other hoses syncronously. if its a hose you should be able to find it.
Old 02-21-2001, 06:03 PM   #6
the spacecowboy
Member#: 765
Post
ok.....will do tomorrow....
what if its not those hoses....what are my other options
Old 02-21-2001, 06:12 PM   #7
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
uhh is the TB seted flat and evenly? thats all i can think of. if its not the exhaust, lets see what tomarrow turns up eh.
Brian aka Bratmantlz
98 2.5RS with 2k front bumper
80 Brat i sold sniff sniff
Old 02-21-2001, 06:14 PM   #8
the spacecowboy
Member#: 765
Post
sorry again for the stupid Q....whats TB stand for
thanks,
space
Old 02-21-2001, 06:18 PM   #9
Pinoy
Member#: 400
1990 300ZXTT
Post
Hey Space I experienced the same thing. hissing drivers side. Don't know how detailed the midas guy was but on mine you could only hear it if you hit the gas. I replaced the gaskets for the headers and viola, fixed. 12 bucks total and about 20 min. of work. Hope this helps
Pinoy is offline   Reply With Quote
Old 02-21-2001, 06:20 PM   #10
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
Throttle Body its not a stupid ? i asked once what ROFLMAO and i was ROFLMAO when i found out what it was hehe hope its a hose thats a hell of a easy fix eh. good luck Spccby
Brian
Old 02-21-2001, 06:23 PM   #11
the spacecowboy
Member#: 765
Post
well i told the guy at midas that it was a header gasket but he said it wasnt that it would of left black carbon depostis all of the aluminum...he said that there was no problem with the exhaust...
i hope im right about it..
thanks,
space
Old 02-21-2001, 11:49 PM   #12
Impy
Member#: 489
Post
I have that too... but im sure its a leack... cuz i have a custom midpipe, mind u its not done very well... i had it for quite a while... i can see the aperture AND the deposit...
Impy is offline   Reply With Quote
Old 02-22-2001, 06:27 AM   #13
Diz
Member#: 874
2015 WRX STI
2004 Mazdaspeed MX-5
Talking
One thing to think about - if you have a vacuum leak, your car should have a rough idle. Also, you can spray carb cleaner around the areas in question while the car is idling. If the rmps increase, the car has 'ingested' some of the carb cleaner and you have found your vacuum leak. Good luck.
-Paul
Diz is offline   Reply With Quote
Old 02-22-2001, 07:22 AM   #14
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
Speaking from experience here. Make sure that your "breather" hoses are all attached. I thought I had an exhaust leak, too, but it turned out that a breather hose had come off on the back of the block (under TB). The car STANK.
Steve
http://www.lagging.com
SteveS is offline   Reply With Quote
Old 02-22-2001, 10:30 AM   #15
the spacecowboy
Member#: 765
Post
well i would be out there working on the car seeing what the problem is but the snow happens to be falling at a e^x rate of speed....so until that all clears up, cant check it...
space
If not Paypal, then what? boomtonic Off-Topic 3 02-15-2005 01:31 PM
2 minute exhaust leak, then it goes away... glilly Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-13-2002 03:33 PM
First it's radiator leaking, then clutch master cylinder resorvoir leaking, and then. davidm_sh Warranty Issues & SOA Problems 1 03-24-2002 01:43 AM
Exhaust leak or what? lestion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-14-2002 12:26 AM
If not unsprung, then what? MBX Motorsports Normally Aspirated Powertrain 0 06-20-2001 10:09 AM
