Old 01-05-2003, 03:36 AM   #1
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default Turbo kit+TEC II+gauges+radio=excessive battery draw?= no spark???
Has anyone experienced not being able to start their cars because the TEC, the turbo kit, and all the guages inside are drawing too much power that there is not enough juice to make the spark plugs spark? I have a Optima RED top battery which is 2 weeks old and I htink has 12.8V? cold cranking power. I also have stock pulleys except foir the trigger wheel is attached to crank pulley and a fuel pump pulley is off the same belt as the AC pulley.
Causes for problems:
1. Need a better battery as in more cold cranking power?
2. Bad starter?
3. Bad alternator?
4. Any other elec. probs that coudl cause excessive draw??
Take in to consideration that this is a MY99 2.5RS
Thanks
John
Cusco is offline   Reply With Quote
Old 01-05-2003, 05:04 AM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Does it crank? If it cranks it's not the battery or the starter or the alternator, unless it is cranking ungodly slowly. Check the voltage output on that battery, it should be around 12 volts. I would check to make sure that the coilpacks are ok and that the plug wires and plugs are fine.
Drac9 is offline   Reply With Quote
Old 01-05-2003, 08:24 AM   #3
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default I think everythign is in workig order
Drac9-
AS far as I know everythign is okay. I have custom cut magnecore wires which are I think about a year to two years old and I think free from abrasion or damage. The TEC coilpacks seem to be responding well and I dont see sany damage or anythign of that matter,. What exactly do you mean check the coil pack? for errors or something? the plugs I replaced about 3 weeks ago and the car just started today so I have only fired them a little over 10 times? could I have fowled them up already seeing how I hear peopel tuning and starting the tEC system tend to fowl plugs very often durign the first month or so???
John
Old 01-05-2003, 11:32 AM   #4
Austin
Member#: 7089
2016 STi
John - gauges and radio have very little current draw. CD players, or large amplifiers (when turned up/making bass) will draw some current, but the radio doesn't.
I don't think you've fouled your plugs yet - not after having only run once on them. You said you started your car once already? Did it die? Did you shut it off? Describe how it started, how you shut if off, and what you've done to it between then and now (now that it won't start).
Also describe how it won't start now - does it turn over/crank? Like Drac said, if it's turning over, it's not the battery. Unlike Drac said, however, it could be the alternator. With a fresh 12v battery, it's possible to start and run the car for several hours without an alternator - all power the car needs is being drawn from the battery. You don't use the alternator to start the car - it only provides power once the engine is turning.
To see if you've killed your battery, do this -
Turn all loads off - radio, dome light, ignition, everything.
Use a multimeter and check battery voltage - this is unloaded voltage.
Now turn on your headlamps (high beams), A/C blower motor on high.
Use a multimeter and check your battery voltage - this adds a bit of load to the battery. If you've dropped more than .5 or so volts, then your battery is discharged. It's not dead, though - you can still charge it back up. If you have no other battery charger, use jumper cables from a running car.
Your battery voltage should be 11.5v to 12.5volts unloaded. As soon as your car's running, the alternator/voltage regulator begin to supply power to the car and to charge the battery. System voltage should be 13.5-14.5 volts. (test at ~2000 rpm)
If, when the engine is running around ~2000 rpm, your system voltage is 12 volts or less, then your alternator is likely crapped out.
Austin is offline   Reply With Quote
Old 01-05-2003, 12:55 PM   #5
Member#: 67
1999 Outlasting
the competition.
question fo you
where did you get your switched power for the tec ? i had something close to the same problem. turned out when the key was in the ON position it was seeing 12V+ but when it went to start the Voltage would go to Zero!. i used the plug for the washer bottle (second plug) after that i used a Multi Meter and probed around till i found a sutable powersource.
[email protected]
Old 01-05-2003, 05:49 PM   #6
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
Default switched battery
I got the IGN switched battery from teh stock coil pack harness. it is the solid yellow wire. I just vampire clipped the yellow wire and routed it to the "swbat", just like SCC did it. As a matter of fact thats what I looked at to find out where to tap the power.
John
Old 01-06-2003, 01:29 PM   #7
cammy712
Member#: 6576
2001 Impreza 2.5 RST
Make sure that the power source you are using does not shut off when the motor is being cranked. That would cause no power to the ignition
cammy712 is offline   Reply With Quote
Old 01-06-2003, 01:43 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
What makes you think the plugs are not sparking?
I've noticed that in colder weather, the car is just plain harder to start. This I've countered by enriching the cold start fuel enrichment parameters and adjusting the warm start enrichment parameters. Now the car starts fine. The Tec2 as I recall only needs 9 volts to operate properly. With a new Optima you should be fine.
Your switched power location should be find. That is what I'm using (was for the Tec2) for the Tec3. Make sure you still have a good contact with that tap. They do not always make a good reliable contact.
The next questions are: How are your grounds? Do you have sufficient grounding to the block and to the Tec2? Do you have your Red Top in the trunk or in the stock location? How many miles are on your stock altenator?
I replaced my altenator at 65,000 miles due to voltage regulator issues.
Revision is offline   Reply With Quote
Old 01-06-2003, 02:18 PM   #9
zaidallas
Member#: 4106
Check spark in plugs : pull one plug out , pull the fuel pump relay out or fuse to turn the fuel off , keep the spark plug inside the spark plug wire and ground the plug to the body of the car and crank it to see if there any spark coming out . Do that for every plug to make sure there's spark. If you have spark , then make sure you have fuel .
zaidoun
zaidallas is offline   Reply With Quote
Old 01-06-2003, 03:57 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what is the ground from the tec 2 connected to battery or frame?
Resolved:Almost_there_1-Rotated Turbo Kit, TBE, TGV's, Gauges, EBC, etc PICS INSIDE Almost_there_1 Scammer Central 39 03-18-2009 02:45 PM
'01 rs 2.5 minnam turbo kit, tec II bmandu Engine/Power/Exhaust 1 02-09-2008 12:48 PM
Vishnu turbo kit, tec II, and Acc. for 2.5rs preza Private 'For Sale' Classifieds 7 06-09-2004 11:39 PM
RS Turbo Kit - Stage II jid2 Private 'For Sale' Classifieds 4 02-02-2004 11:03 AM
Shiv's 2.5 rs turbo kit and tec II kit preza Private 'For Sale' Classifieds 4 10-08-2003 11:51 PM
