Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 01-05-2003, 10:23 AM   #1
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
Default Car Wont Start... Fuel Pump Not Priming... Any Ideas?
I was having problems with my front 02 sensor... it was crapping out... still the car ran and I drove it from time to time to keep the fluids circulated, that is until the new O2 sensor came in, which it hasnt.
Anyway, the other night I drove it out... it wouldnt rev over 3k, then when I attempted to mechanically rev it over 3k by putting it in 2nd and releasing the clutch (ie- coming up to a redlight) the car backfired and the engine stalled.
Since that I have not been able to get it started. At first I thought the o2 sensor completely crapped out (fromt the backfire)... but replaced that and no change. Then I noticed the fuel pump wasnt priming.
I have a Walbro 255... plus a Vishnu Unichip and EMI board.
Today I am gonna swap out the walbro pump for my stock unit and see how that goes... is there anything else I should check?
Perhaps a specific fuse/relay... or wire that may have blown/been cut?
The car is turning over just fine... no ther issues... please advise...
Thanks,
def
dug-e-fresh is offline   Reply With Quote
Old 01-05-2003, 11:25 AM   #2
thejean
Member#: 17763
I had that same problem after installing my up-pipe and all I had to do was just hold the key on for at least 15 seconds and she finally fired up.
JC
thejean is offline   Reply With Quote
Old 01-05-2003, 12:14 PM   #3
Austin
Member#: 7089
2016 STi
Look in this thread: Fuel Pump Options . Check all the points we talked about for 12 volts.
Do you hear the fuel pump relay click when you first turn the key?
Austin is offline   Reply With Quote
Old 01-05-2003, 01:40 PM   #4
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
no relay click... when I turn to the on position (no starter crank), there is no noise at all...
thanks for the link I will check it out...
def
Old 01-05-2003, 06:02 PM   #5
Austin
Member#: 7089
2016 STi
Check the #11 fuse in the fuse block by the driver's left knee. That's the fuse that powers the fuel pump. It's a 15A fuse, and it also powers the ignition, air bags, and something else I can't remember right now.
Old 01-05-2003, 06:09 PM   #6
BlueDemon
Member#: 10173
2005 WRX STi
He said it turns over like it should......... it just won't start, because no fuel is being pumped into the engine. So it won't be # 11 fuse.
Did you install the fuel pump filter when you put that whalbro in? If not, you may have clogged the pump, or possibly, like you have thought, your wiring may have gone bad, or been dislodged.
I dunno about that stock unit........ it won't run the right amount of fuel you need if you're going to be driving a lot.
If you just want to see that it's the pump, then put the stocker back in, and if that fires your baby up, then you need to get yourself another 255lpm high flow Whalbro again..... or if you don't like them anymore, some other plug and play pump.
BlueDemon is offline   Reply With Quote
Old 01-05-2003, 07:02 PM   #7
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I appreciate the responses... I know that the stock unit really wont be able to support the fuel requirements I need... I plan to run lower boost if that turns out to be the problem.
What I may do is just throw a multimeter on the pump harness plug to be sure the voltage is getting to it. If so then the pump is to blame.... if not... then Ill have to work my way forward in the car.
I will have to check the #11 fuse... being that it powers the ignition AND the fuel pump, it makes since that this could be a bad fuse. Remember, an engine turning over is a function of the starter, not the ignition or the fuel pump.
I really hope it could be sooo simple... we'll see I guess.
Thanks guys...
def
Old 01-06-2003, 10:42 AM   #8
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I am an idiot... of all the things to think of... a simple blown fuse was one of the last things I checked (until Austins post).... sure enough, fuse #11 was the culprit. I mean I was gonna get around to checking the fuses... really... but, I guess the lesson here is, CHECK THEM FIRST!!
Popped a fresh one in and she started right up. Now the question is, why did the fuse pop.
Well, my O2 sensor is definitely going bad. It wont rev over 2k when cold.... and when warm it'll only go to 3k.
BUT, then it backfired once and all of a sudden it would rev smoothly to redline! Weird... kinda wonder if the O2 sensor isnt built up with carbon and the backfire cleaned it off or something (ie- carbon=running real rich= what I think below).
But my take on the fuse blowing relates to the O2 sensor.... I think because its having issues, the ECU doesnt know the A/F, and thus out of safety it may be kicking the fuel pump up to super duty... the extra draw may be whats burning out the fuse... well see... I gotta data log to see what the duty cycle of the pump is...
Thanks again guys!!
def
Old 08-05-2011, 01:53 PM   #9
nightkid88
Member#: 252703
I have a problem with my 02 wrx the car wont start and I dont hear the fuel pump priming. I thought it was the pump so I bought a walbro 255 installed it and nothing any ideas maybe a relay or a bad ground?
nightkid88 is offline   Reply With Quote
Old 08-09-2011, 12:28 AM   #10
nightkid88
Member#: 252703
bump does anybody knows where the fuel pump relay is oon a 02 wrx
Old 08-09-2011, 04:35 PM   #11
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
Its on the passenger side kick panel. a green clip connects to it.
neo277 is offline   Reply With Quote
Cold - Wont start and pump not cycling frederik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-06-2009 08:53 AM
Fuel pump not priming? silentt Subaru Conversions 9 08-24-2008 11:58 PM
Fuel Pump not priming ** prodriveuk Newbies & FAQs 3 04-15-2006 02:13 PM
fuel pump not priming/ecu not on? attitude Engine Management & Tuning 16 06-24-2005 01:16 PM
fuel pump will not prime, car wont start had to get towed! GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 17 03-24-2004 12:07 PM
