Old 01-05-2003, 11:32 AM   #1
TriniTuner
Member#: 4123
2004 Acura TSX
Satin Silver
Default Alignment settings for Auto-X
Anyone knows good base alignment settings for Auto-X. I tend to like my car on a pretty even balance with a tendency to oversteer if anything.
I'm taking my car in for alignment soon and so was wondering...Thanks a lot
TriniTuner is offline   Reply With Quote
Old 01-05-2003, 11:38 AM   #2
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
what class do you want to run?
DS?
STX?
ESP?
ChrisW is offline   Reply With Quote
Old 01-05-2003, 04:55 PM   #3
jumbo
Member#: 31234
03 wrx wagon
kind of a bright blue
Default DS setups
I have the same question.
What would be a good conservative setup for a DS novice?
By conservative I mean what would be a good setup to learn on without introducing unpleasant street effects.
I assume max neg front camber.
Can't change rear camber.
Anything else worth changing or would it make more sense to wait until I get better?
jim
jumbo is offline   Reply With Quote
Old 01-05-2003, 05:19 PM   #4
TriniTuner
Member#: 4123
2004 Acura TSX
Satin Silver
Oh, I run STX. I'm not a novice by any means though.
Old 01-05-2003, 05:19 PM   #5
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
if you're still driving a lot on the street you can go with 0 toe all around that should be pretty good
if you want to go more extreme you can play with some toe out but it'll be a pain to drive on the highway, your choice
this has been covered a lot of times before
ellisnc is offline   Reply With Quote
Old 01-06-2003, 10:04 AM   #6
Subdued
Member#: 15904
05 Impreza
09 Tribeca
Lightbulb
Searching on alignment will give you a ton of threads to read and a few contradicitons. Try this one out. http://forums.nasioc.com/forums/show...ight=alignment
Subdued is offline   Reply With Quote
Old 01-06-2003, 10:23 AM   #7
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Hmm, so youre not a novice by any means, and you have no idea about an alignment?
DS
-1.5 front camber, loosen everything, beat on stuff with a hammer and you will be able to get -1.5
1/16" toe out in the front
Stock rear camber, loosen everything, beat on it and try to get it a bit more positive.
A LOT of toe out in the rear. Adjust it when you get to the event. Its pretty easy.
STX
-2.5 to -3.5 camber in the front. Depends on setup.
0 toe
-1.5 to -2.5 camber in the rear. Depends on setup.
0 toe
-Tom
trhoppe is offline   Reply With Quote
Verify these Alignment settings for me please... ScreaminFast Brakes, Steering & Suspension 12 04-12-2004 10:16 AM
max alignment settings for daily driver? iloveturbos Brakes, Steering & Suspension 16 12-03-2003 12:32 PM
Alignment settings for KYB struts/M2 springs on WRX? WRX-Hellfire Brakes, Steering & Suspension 6 11-24-2002 09:54 PM
Any good alignment settings for WRX wagon? blkwag Brakes, Steering & Suspension 6 11-22-2001 06:26 PM
Any alignment setting for TSD rallying? Ben Brakes, Steering & Suspension 3 12-06-2000 08:08 AM
