Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 02-21-2001, 10:58 PM   #1
Member#: 2677
2001 Lexus IS300
Post What stock internals need to be replaced to run 10 PSI safely and reliably? (EJ25)
Just need some input. Cobb Camms are already on the list but what else?
wrxman555 is offline   Reply With Quote
Old 02-21-2001, 11:01 PM   #2
Member#: 329
1995 325i
Arctic Gray
None, providing the motor is tuned correctly.
Edit: by internals, I'm assuming you mean the stuff inside the block.
[This message has been edited by RidinLow (edited February 21, 2001).]
RidinLow is offline   Reply With Quote
Old 02-21-2001, 11:03 PM   #3
Member#: 922
16 WRX (white)
04 FXT (red)
Transmission & rear diff helps.
Old 02-21-2001, 11:28 PM   #4
Member#: 3115
2002 Impreza 2.5RS
Yeah nothing needs to be changed, just ask Shiv over at http://www.vishnuperformance.com/ Him and his Tec-II work well for Hi PSA
RawCode is offline   Reply With Quote
Old 02-21-2001, 11:38 PM   #5
Member#: 2692
I'd go a step extra and get a set of pistons
with slightly lower compression (as long as you stick to 10psi, you're not a boost junkie, are you )
[This message has been edited by kaos200 (edited February 21, 2001).]
kaos200 is offline   Reply With Quote
Old 02-23-2001, 12:23 AM   #6
Homicidal Maniac
Member#: 1612
2008 STI
If the RS is a MY98 or MY99, then you should be fine with basic engine management. If it is a MY00+, then there was an increase in compression ratio and, therefore, a lower maximum boost. Full engine management would probably be the best thing in that case.
what needs to be replaced if airbags deploy? Skiracer8148 Service & Maintenance 10 03-20-2009 07:26 PM
Can I run 20 psi safely? irishsetter Legacy Forum 31 08-02-2006 02:55 PM
Removing hub, what needs to be replaced? edubb11 Brakes, Steering & Suspension 9 06-24-2004 09:23 PM
10+ psi safe? lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 6 02-15-2004 08:20 PM
TXS stage 4- what other mods have to be done to ensure safety and reliability? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-26-2002 02:18 PM
