Old 01-05-2003, 03:50 PM   #1
juztin180
Member#: 11804
Default found conisderable amount of oil where boost controller Y's off
I put in a turboXS unichip(stage2) and now where the "Y" for the aux. boost controller is there seems to be quite a bit of oil. There is also a lot in the little clip that holds the wiring (round clip down near DP and wastegate)
where is it coming from and how worried should I be
I just put the stock valve on after taking off a TUrboXS type H bov, so i'm wondering if that might have something to do w/ it? I dunno
juztin180 is offline   Reply With Quote
Old 01-05-2003, 10:32 PM   #2
juztin180
Member#: 11804
ttt,
can anyone help me out, here are a few pics i just took
This is the Y section where the aux boost controller Y's off. There is oil on these two hoses. Can't tell if its coming from inside the hose or squirting onto the hoses
this is the clip that has oil in the bottom of it. Its in the lighter area of the picture. This is just to the left (facing the car) of the Y for the boost controller. You can also see on the line running by the wastegate that there is oil on it as well.
more of the clip:
any ideas where I should look?
Old 01-06-2003, 10:53 AM   #3
juztin180
Member#: 11804
so nobody knows huh?
Old 01-06-2003, 01:53 PM   #4
juztin180
Member#: 11804
60+ views and not a reply from anyone.
THANKS!
Old 01-06-2003, 02:15 PM   #5
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Default ?
sorry cant help, maybe everyone is like me and has no ideas, and did not take the time to respond.
cnstman is offline   Reply With Quote
whats a normal amount of oil burned? needawrx13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-19-2008 04:59 PM
Large amounts of oil in the intercooler elusiv Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-19-2008 09:01 PM
excessive amount of oil in my intercooler 257_666 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 11-29-2007 11:24 AM
how to get the exact amount of oil in the engine BlackoutWRX Newbies & FAQs 35 05-09-2006 08:38 PM
STi, small amount of oil on spark plug BrandonWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 12-26-2005 02:31 AM
