Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 02-22-2001, 12:08 AM   #1
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Post Could the factory 's low amount of tranny fluid have hurt it?(kinda long)
I have been driving my RS for almost six months now and I checked the tranny fluid today and there is a tiny drop showing up on the dipstick(well below LOW). I am going to put some more in but could this have damaged anything? I have posted before because of weird noises I hear from the tranny while downshifting. I have the subaru shift kit and someone else with a 2001 with the shift kit is experiencing the same thing. He also had a low tranny fluid level and has about the same amount of miles. I am taking it in to get it checked out but my dealership does not seem to know much. I think I will call SOA before to see if they have any info. Is it me or is this really lame? Why don't they check the fluid level? I hope to get this tranny problem/noise resolved soon along with my cold shuttering clutch.
scootr is offline   Reply With Quote
Old 02-22-2001, 07:19 AM   #2
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
Hey scootr
Just a note. When did you check the fluid? You cant check it when the vehicle is running or just finished running. It has to be on level ground, and been shut off for a while. If you check it right after you shut the car off it will read VERY low. Check your owners manual for correct method to check the fluid.
Just a note you might want to check, so you dont overfill your tanny!
SCRAPPYDO is offline   Reply With Quote
Old 02-22-2001, 11:52 AM   #3
Member#: 2185
I checked mine at 5k and it was low, no matter when/where I checked it. No dealer would tell me what kind to use and wanted me to bring it in. Since it's under warranty, and the tranny could be leaking, they checked it out, found no leaks and filled it up, no charge of course. I advise everyone to check their fluid ASAP. Thanks for bringing this up, scootr.
#522 is offline   Reply With Quote
Old 02-22-2001, 03:15 PM   #4
Member#: 3728
Thumbs up
You're definitely not alone..I checked my fluid at 100 miles & the dip stick was bone dry!! (yes, the engine was off & it was on flat level surface). I ended up putting a quart of lubricant (Pennzoil Gearplus SAE 80W-90 GL5) into it. I then called the dealer
& asked why they didn't prep the auto properly (at a minimum they should have checked all fluids). I also notified S.O.A. when I filled out my dealer satisfaction sheet the other day. Fortunately I checked this before putting any extensive mileage on the car.. Yes I called the dealer & they also said, maybe it was leaking..Well it's not leaking, it was just never properly filled & they were too lazy to check it before selling me the car.
Shifter is offline   Reply With Quote
Old 02-23-2001, 07:58 AM   #5
Member#: 767
04 FXT
Never assume that your fluids are correct after a service or even when picking up a new car.
Shifter - smart move with the customer survey and calling SoA. Subaru does read those surveys. Just ask the former Service Manager at my former Dealer.
Changed tranny fluid at 9K, it is noticibly darker than new fluid. Please help! 4EAT Obsessive Transmission (AT/MT) & Driveline 4 07-07-2010 12:04 AM
Dallas: Anyone have a bit of tranny fluid? fatcircles TXIC Private Classifieds 1 02-05-2008 11:58 PM
What is the longest amount of time you have stayed up? (consecutive hours) dr_wheel Off-Topic 59 08-29-2005 05:58 AM
Whats the largest amount of water you have ever drank in one day? huckedup16 Off-Topic 34 05-20-2004 04:31 PM
What is the longest amount of time you have gone without seeing your S.O.? quentinberg007 Off-Topic 31 02-09-2004 01:18 AM
